Pretty solid downhill, but I find it hard to believe I hit 53.5mph. A friend who also did this MS ride says he hit 54.1mph (he didn’t make the turn at the bottom), but I almost believe both are in error rather than both were that fast. Does my Garmin 500 use wheel size or GPS to determine speed at any given point?
It depends, do you have a speed sensor, and is it paired with your Garmin?
I’ve had many rides when Strava messed up my max speed. I think I had a ride this summer with a 60mph top speed on strava which was only 40mph on my bike speedo sensor.
Average speed will be fine - but any one data point might be a bit off.
I’ve recorded north of 50 when I know I wasn’t doing much more than 40.
My top speed was 56 mph with a wheel magnet computer and I was with a tail wind and pedalling out my top gear. Of course - a lot depends on the hill you’re descending.
Were you actually riding 100’ to the right of the road in the woods? That’s where your GPS tracked you. Your speed was calculated from the GPS points that are not very good so no, you did not hit 53 mph.
Just own the pace. Garmin makes me a much faster athlete than I truly am at times. Have gone 28 miles running for three minutes and my last ride I was going 78 miles an hour up hill for 10 seconds. It all averages out in the end, but no need to invalidate your Strava result as everyone gets these readings from time to time and Strava does a good job of spotting them and evening it out.
Also, if you are a decent or better cyclist and descend without staring at your computer, you’ll be surprised by how fast you end up going and this could very well be accurate. You didn’t set a CR there either, so it may also be a fast stretch of road.
From what I see, your path is way off the road and perfectly straight. Seems to me you lost GPS signal for a while. Looks like the software calculated speed based upon time and the distance between where you lost and got the signal back. I’d say it’s a bogus reading. FWIW one time I paused my FR305 for a while and forgot about it. I restarted it after a couple hours. I can’t remember the exact speed, but Garmin connect calculated me going something like Mach 2.
Rode up Federal Twist on Saturday morning and saw two riders going the other way - the guy in front was in a decent aero tuck and I’d say he was probably around 50mph. My riding partner mentioned after we dropped down Tumble Falls Road that he’s seen a lot of people hitting between what he estimated at 50-60mph on Federal Twist.
Eye-balling the difference between the curve length and the road length where they separate and estimating the right triangle angle I’d guess the GPS added 53.5=x/cos(15 degrees) ==> x = 53.5*(.965) = 51 mph. I’ve gotten to 50 mph on 6% straight descents, so it’s probably close to real.
