Very equal, but for caffine if you have that in your Gu and any electrolites (again, if you have that in your Gu). Karo syrup works too…Aunt JoMomma and many other ‘syrups’…
Yeah honey should be fine. Carbohydrates are carbohydrates, and honey should be a fairly quick source of energy. I use chocolate frosting sometimes. As for fig newtons being natural, look at ingredients, but hey its still energy so go for it. Make sure you are getting electrolytes too (salt stick).
I made up a flask of honey 3 parts , blackstrap molasses 1 part , water 1 part, pinch o salt, and 1 starbucks instant coffee . Not bad with the exception that it frothed and foamed pretty good when half empty. Rather stick with ready made.
It was probably the instant coffee that foamed up on you- was that just in there for the caffeine? If so, just ditch it. If you really need the caffeine, why not mash up a NoDoze instead? I’ve always found that instant coffee bothers my stomach anyways.
If you’re really looking to homebrew, use “lite” salt or sea salt instead of regular. Sea salt and lite salt will have a mixture of sodium and potassium, whereas normal table salt would just contain sodium.
that agave nectar and the sorts are ok. but make sure the syrup doesnt have tons of added refined sugars
imo the best “natural” solution would be blended soaked dates. really high in glucose and easy on the stomach. although you may not notice a difference with 2-3 hour races/training sessions, you may notice the difference between honey and dates during the end of the bike or run of the ironman. honey is a little more rough on the stomach
listen to burnman - wise advice.
Honey Stinger is natural and has the added electrolytes and caffeine in certain flavors.
The gel packets and bars are excellent fuel for training and racing.
It’s all I use, but then that might be obvious by the tag line.
THanks for that info. Interesting stuff and all good comments. I’m thinking about playing around with a blended soaked dates, honey, water, electrolytes combo. Maybe a small amount of lemon juice to act as a preservative. Maybe get 1 week out of it in the fridge.
