I see some of these posts about the water bottle between the bars and how they splash and lack of refill options etc.
I got bored at work - so looked around and found a “wine bottle re-corker”. Its a ridged plug, with a rubber mesh filter, and cap. Seals pretty solid but is easy enough to pop out to refill on a ride. I still have to figure out a cheap straw option but for the price of a $3.00 tube of silicon, $4.00 wine corker, and gatorade bottle…thisl work.
It is an “add on item” but I had ordered something else. They sell all sorts of packs of them for around $10.
The silicone is just regular home depot stuff. I put it around the lip of the cork so it sealed on the outside, thus not really getting in contact with whatever liquid is in the bottle. I cut the hole very small so it is a super tight fit even without silicone.
various widths and types of plastic tubing is/are to be found cheaply at hardware stores. i have used rigid and pliant types over the years on a set-up i made up. it was well under $1, either type, and worked very well.
peggy
I was lookin at these rubberish “smoothie straws”…they are a little thicker and wider in diameter and could probably be rigged with a bite valve. Ive yet to stumble upon a perfect cheap solution haha
Yep. I have a similar setup (1L nalgene bottle), with the main difference being a much smaller straw port with PVC tubing squeezed into it, such that there’s no space for leaking around the tube. Tubing comes in all dimensions, with wall thickness determining the rigidity. They can be found at your local beer brewing store for super cheap or online if you know the dimensions you want. You can also boil it in order to bend or straighten it for your purposes.
Amazon PVC tubing
peggy
This looks great and got me thinking. I have the Xlab Torpedo, but can actually see some benefits of this solution over that one. I didn’t love how the Xlab filling port interacted with the on course Gatorade endurance tops.
After what you’ve come up with there, this may seem too inelegant, but for a straw option, you can pop or drill out the center of the cap and silicone in a piece of surgical tubing. It can attach to the bottle using small pieces of velcro with adhesive backing.
Personally, all I need for a 70.3 is that bottle setup as a BTA and then the hydration bladder on my Shiv. No need to stop at aide stations or fiddle with refilling from bottles behind my saddle.
Because that is one tiny tiny hole to refill, heck it would be hard to fill while standing perfectly still on a windless day. But in motion? That looks nearly impossible. But if I’m off base, how do you do it? How well does it work?
I agree with DarkSpeedWorks, that refill hole seems quite challenging to use while in motion. I have look into doing this myself and I found out that Xlab sells a “Torpedo refreshing kit” which includes refill valve and straw for $13, it may be worth a look.
If it’s a tight fit, it doesn’t even need to be siliconed. After you drill, do a little light sanding to make the surface smooth, then stuff the tube in. Like I recommended above, food grade PVC tubing works really well.
Those Gatorade Endurance bottles they hand out on the bike have huge tops, hope you’re not planning on using them. Might work with a water bottle, but I’d end up with half the bottle rinsing my front wheel.
Not sure about other races, but at Mont Tremblant, I believe both the gatorade bottles, and bottled water they hand out, both are the spouted top type, so you can squirt a thin stream from them.
I like this idea by the OP. For me, I hate using a straw, just like using a normal bottle BTB and removing quickly to take a drink. But would still be nice to be able to refill it…might try this.
