I live in Massachusetts and have gas heat. We out in heat pumps 2 years ago mainly for the a/c. First winter we used them solely for heat and they kept up fine but struggled a bit in a couple short really cold periods (10-20F).
What we realized is that the gas heat uses more energy but is cheaper to use right now for heat since electric rates skyrocketed this past year. So we used gas heat this winter. In the buffer seasons we use the splits for heat since they don’t have to work hard so are more efficient and cheaper.
I think they will keep up most of the time on LI and might be cheaper in the winter than oil. I would want a backup heat source for 2 reasons…
This winter our furnace broke a bit so it was great to have backup heat for a bit.
Last year my sister in laws pipes froze so they weren’t able to use their furnace for a few weeks but thankfully they had splits to use for heat for a month. It’s really nice to h e a backup.
MA resident here too, and considering mini-splits to supplement our current oil heat paradigm (and give us some cooler air in summer).
Do the splits and the furnace ‘talk’ automatically, or do you have to manually turn one on, and turn the other off?
The mini splits and gas furnace do not talk to each other. We power one system on and the other off and vise versa. They may have some that do talk but I dont think they do.
We had to get oversized units for our house to meet rebate requirements (weird that bigger met requirements and smaller didn’t) but they are engineered to only work as hard as you need, so bigger is not really a whole lot less efficient. I would not undersized them, they just work harder/less efficiently and struggle to keep up.
We got nice Mitsubishi and they are wall units. I really wish we had ducts so they wouldn’t be mounted on the wall but it is what it is.
We got about 5k in rebates and a 7 year 0% loan which makes the whole thing pretty reasonable
Also in MA here (just south of Boston). We just installed a ducted heat pump system in our in-law addition and it’s been great so far. No issues heating the in-law apartment through the winter, although it’s new construction with spray foam insulation which helps.
We don’t currently have central air in our main house and recently converted from oil to gas heat (forced hot water), but we’re going to install a ducted heat pump system there too. One air handler for each floor with a common heat pump, and new ductwork in the basement ceiling for the first floor and attic for the second floor. The contractor says he can integrate our existing hot water heating with the heat pump via smart thermostats. I’m not totally clear on how they work together but I assume the heat pump will be the primary heat source unless it needs help from the boiler.
*edited to correct my terminology.
