SPEED WOBBLE
When a customer brings his bike into his LBS and complains of speed wobble (death wobble, front-end shimmy) often the typical bike shop mechanic immediately starts farting around with the headset adjustment. There is no adjustment problem, nor are the wheel bearings loose, and in fact it is most likely that nothing is wrong at all.
Speed wobble is just an inherent “flaw” of bicycles. Bicycle frames are amazingly stiff and strong in a vertical plane, but horizontally they are not. They are like ladders, and when you stand on a ladder it is strong, but when you and a friend stand a distance apart, each of you grasping one end of the ladder, and you twist, the weakness of the ladder is apparent.
In that same way, when a bicycle is moving in a line straight ahead, and gyroscopic effects of the wheels weigh on a unit as elastic as a bicycle frame—with its fork and wheels—you might get shimmy.
Shimmy occurs at a certain speed, depending on the bike and the rider. I have heard it said that every bicycle is prone, depending on its geometry, materials, and rider position, a particular resonant frequency, at which the bicycle oscillates. All that occurs when a given speed is reached on a descent.
The shimmy will stop if the rider unloads the saddle, because the mass of the rider is the anchor about which the oscillation operates. It may also be helpful to place the inside of your leg against the top tube on a descent when you experience a shimmy.
Certain elements will make the bicycle more prone to oscillation. All other things equal, those elements that render the bike more elastic will aid in its ability to shimmy. Therefore, a longer head tube will make the bike more likely to shimmy. Lighter, thinner tubes will make the bike more prone to shimmy. I suspect that shimmy might be more prominent now than in days past because bikes are so light, and their components somewhat more susceptible to lateral flex.
Shimmy is more likely in cold conditions, or when a rider is nervous and grips hard on the bars, because the vibration of a shivering rider is roughly similar to that of a frame’s shimmy frequency, and this can help bring on the shimmy.
Therefore, while speed wobble is disconcerting, if you can adopt the habit of unweighting the saddle during a long, straight descent any shimmy problem should be largely abated.- Dan Empfield, here quoted.
I’ve lowered my aerobars, thus shortening the effective head tube height. Seems to help a bit. I may go lower at MT because I’ll be spending quite a bit of time climbing anyway. At least I hope I’m climbing and not stopped!
-Robert
