Wetsuit tips and tricks
I have done some open water swimming over the years and thought I would give some tips and tricks that have worked for me - for athletes getting ready for their upcoming races.
There are many others that know wetsuits, wetsuit construction and have used them far longer than I have - so I’m sure we can gather some additional ideas as well as corrections to my post - but I thought some constructive use ideas might be helpful.
Practice swimming in your wetsuit once a week so you get used to it.
Products like Glide etc. don’t work well for me. It is very important that you can get the wetsuit up smoothly. Purchase a tub of coconut butter (looks like Crisco) at the local grocery market. This stuff works better than any other product I have tried and its cheap. It does not matter if you have a speed suit or bathing suit on under the wetsuit – put butter on your feet, lower legs, sides of hips, chest, shoulders and neck or (over the under garment). You will be amazed how easy the wet suit goes on.
Pull the wetsuit up high. When you think its high enough – pull it up some more. No sags in the crotch. This will take a ton of pressure off your shoulders, neck and chest. When its up high and fits correct its a great feeling to swim in it.
Keep the neck attached but loose.
Before you get in the water pour a bottle or two of tap water down into the suit through the neck. It will create a nice warm boundary layer and will help let new fresh water in to keep you cool as your body temps rise from exertion. This is not a dry suit – it’s a wetsuit – literally.
If you are going to wear a sports watch – take it off, put the suit on, roll back the sleeve and then put on the watch and roll the wetsuit back down over it. Much easier to get on and take off after the swim. Same for timing chip.
I have big feet so I also cut off about 4 inches from each leg so I can get the wetsuit on and off easier. Scissors work fine and no need to seal it – just a nice straight cut.
To save energy sighting (and if they are a good swimmer and they can sight) I try and just get on the hip of a slightly faster swimmer. It cuts my sighting by 75% and I get their cut through the water so I use less energy.
Foggy goggles. The only way to have them not fog is if they are new (it lasts about a week) or if you don’t mind a few drops of water inside. Nothing else works. Baby shampoo, spit all that don’t work for me…just a few drops of water. The differential in heat between your eyes and the water will make condensation – no getting around it. A few drops of water will continuously clear it.
At swim out take your time and pull off the arms and top down to your waist and run to your bike. At the bike pull it down – sit on the ground and pull off each leg. The coconut butter will make this really easy. You will not need to stomp on it and tear at it.
Good luck - I hope these idea help and hope others will chime in with what works for them :-).
Dan
