I need help to decide if size is 48 or 51 for a new felt ia advanced. today I have a cervelo P5 2017 size 48. I will try to give as many as possible info that I have:
Height: 168,5cm
Inseam: 76,5cm
Pad stack: 624mm
Pad reach: 403mm
Height: 168,5cm
Inseam: 76,5cm
Pad stack: 624mm
Pad reach: 403mm
I was gonna say 54 based on your pad stack. But given your inseam, the 54 might be a bit tall in terms of where your saddle height would be (do you know your saddle height??).
So between a 48 and 51, I’d def say 51. I don’t even know for sure if you can achieve a 624 pad stack on a 48?
Here is a pic of my -54- with a pad stack set at around 640, so only 1.6cm higher than you. I think you can imagine you would have a really really high stack on a frame 6cm shorter than mine…
Saddle height in pic is around 73cm.
EDIT - just saw you cervelo fit. Your saddle height is only 1cm lower than mine. I’d def say go with a 51 over a 48. And I would consult a Felt dealer first and make sure you shouldn’t be on a 54.
Also, I believe the frame stack of your 2017 P5 48cm, is actually almost 2cm higher than the frame stack of a ‘48’ Felt. That is why you likely need the 51 in the Felt, not 48…
The felt dealer that I am talking to, has a 48 in stock and can order a 51 for +$75…. And said both can be fitted for me based on my fit numbers… just suggested me to upgrade a riser kit and extensions bars from profile design…
I am attaching a compare measurements of all 3 models… felt 48, 51 and my P5 48….
