Dear tridam,
I’ve read your post and I feel your pain. I am a non swimmer working on my 3rd season of reformation.
My 1st TRI was a 300m OWS, I’m not sure I ever recovered the rest of the race but I did it.
My next TRI was a pool tri. At the end of my first season I tried a 750m OWS. I literally swam at least 1500m but I finished. I used to swim very crooked with no constant form or rythm.
Okay so you swim 100m in 2:20. My advice is simple, slow the hell down so you don’t need all the breaks. Yes read TI or watch the videos and learn to float! Floating gives you a safe way to just chill if something goes wrong. It also helps you learn body rotation and breath control. If you can’t float, you will never be able to tweak other things wrong with your form. My swim coach now has me working on stroke timing and is fine tuning my kick. I’m still slow but I’m very efficient now and swimming is just a warmup for me. I’ll get faster soon, but I’ve been working on it a lot longer.
Your TRI is in May and you need to finish 700m… you need to swim 2 or 3 times a week for one hour, not 30 min. You need to get where you can swim 1000m in a pool without taking a break. At 2:20 you are likely taxing your aerobic system with bad form. Work on your form (floating perfectly horizontal) and swim slower. If you have to swim fast to swim, then you have bad form. You should be able to float across the pool at whatever speed you choose. Another thing to consider is the guys at findingfreestyle. They will coach you via video and help out a lot. Their program is geared more towards stroke timing and less towards floating / body position like TI, which is why you may want to consider both.
You can do it, but you need to work at it a lot. I’d bike and run less and swim more in your situation.
My goal is to complete a half ironman this season (not set any records). I joined a local club with masters swim classes and am getting my butt kicked by them 3 hours a week. It will ultimately make me a much more competent swimmer. I’m just hoping to be a swimmer and stop being a thrasher in the water.
Every open water triathlon I do some inexperienced swimmer takes off way too fast out of the gate and quits. Don’t be that guy. I’m not fast so I start to one side in the back of my wave and swim my pace… slow and steady. I usually end up passing a few people towards the end and of course all the people that hang onto the kayaks or call it quits. In my last OWS tri I actually was in the middle of my AG for the swim. You can get a lot better in a short time if you focus on the right things. I would highly recommend an OWS clinic near you for triathlons if you can find it. Knowing how to react when you get kicked, hit or have your goggles knocked off can be a huge life saver too. It is important to know these techniques too in order to manage your 700m swim.
I’m staring a 1500m OWS in the face in early June and it still scares me a bit. I can swim that distance in a pool easy, but I haven’t done it in open water yet while other people are trying to beat you… or just plain beat you in some cases.
- Slow down and swim more… lots more.
- Learn to float (TI is good for this)
- Consider findingfreestyle for stroke tips
- Take an open water swim clinic or two
- Get swim lessons or a swim coach
I would strongly consider all of the above as time, finances and your situation allows.
