I have the Hed Jet90’s and love them. Lighter and deeper than the flashpoint wheels. I also love that they are supremely stiff. Others may not like that.
The HED’s will be carbon clinchers I’m pretty sure. That means that you will have to use the carbon specific brake pads as the braking surface will be carbon or basalt or whatever and can’t hold up to normal pads (too hard). Anyway, I use carbon clinchers and it’s no big deal to change the pads. I just removed the Shimano pads (1 little screw on each brake shoe) and slipped the new ones right in and tightened the bolt. They are already lined up and everything. Took about 5 mins total. Anyway, I love the carbon clinchers and I think you will too. I wouldn’t discount the Flashpoints though. I rode the 60’s and they are pretty sweet.
Well I’m down to Hed 69 jets or the Flashpoint 60s wheelsets.
I keep hearing flashpoints are heavier, but honestly I’m not even sure if the weight will make that big of a difference for me. I’ve not really read much comparision between these 2 wheels, as my budget is about $1500 on wheels or there about.
the clinchers (jet 90) have an aluminum braking surface so no need to change. The Jet 90 are the tubulars that have carbon braking surfaces which you will need to change the pads.
Is it that big of a speed difference between clincher vs tubular, or is it basically “comfort of wheel choice”.
No, there’s not a big difference in speed of clincher vs. tubular. Comfort is probably a bigger factor, and Jet C2s at 90PSI are darn near comparable in comfort to a tubular.
