Hi everyone. I was wondering if anyone had a good protocol or guide to preparing for a hot humid race.
I will be training in the cold norther hemisphere with temps around 20-30 degree Fahrenheit. My race is in 90 degree heat with high humidity. I will arrive a few days early but I have heard of protocols to start before had.
Training adaptations will take at least 2 weeks, IIRC, and you should aim close to your target race. For outdoor training, heavy cotton sweatshirts, pants, skigloves, and hats really hold in the heat and can simulate what you’re looking for. I personally use a treadmill/trainer with no fan and long sleeves. Keep an eye on your hydration. Doesn’t have to be every session, but the more the better. Just keep in mind this will hinder you, so I wouldn’t think it’s a good idea for VO2max intervals–but easy/moderate should be ok, and some race-pace to get dialed in will be a benefit. Plus, you’ll be mentally prepared.
Sauna or hot bath. Look for heat acclimation protocols / studies (google) that involve this. From what I read start with 10-15 minutes and add a few minutes every session. Begin about 15 days before the race and stop 3 days before. These can be quite taxing so reduce intensity and volume of s/b/r when doing this. Since you’ll be tapering anyway should be fine. Make sure you rehydrate and supplement electrolytes after each session.
I followed this for 10 days for a hot race last year and worked really well for me.
Did Cozumel last year coming from California. Did a couple things the last 3-5 weeks before the race
-Dry sauna - started with a shorter time, just a few minutes as it was harder than I thought. After swim. Worked up to about 2 x 10 minutes
-Trainer ride, no fan, long sleeves. No power goals or hard workouts, just getting used to it.
Worked reasonably well I think.
I also used de soto arm coolers for the race, which don’t provide a ton of benefit in a humid race, but they were good on the bike keeping me cool when wet with the wind
