My old erg would drop resistance when it got hot, maybe that’s it?
It is a Wahoo Kickr 2017. I have just calibrated it, but it could of course be that erg mode is flawed. Doesn’t feel any different though.
That sounds like a hellish workout too
Oh but it is. Did it as 1x20 + 4x20 TT and added 2x5 upright afterwards which I will build up to 2x10 upright for a total of 80min at around threshold. This is a part of either double or triple interval day in accordance with AT.
A drop in heart rate that large indicates a reduction in stress.
The first thing I would look at is if the resistance is fading.
I don’t know how to check if my kickr is off. My Power meter pedals are on their way to Italy for service. Any suggestions?
6x10 min sounds crazy, what % of FTP are you riding at? If work set is >90% of FTP you need to re do your threshold testing.
A lack of HR responsiveness through set is to be expected although the degree that you are experiencing is extreme. Do some mile repeats on the track at 0.5:1 rest interval and see if you are experiencing similar HR decay to determine it is you or the trainer.
It doesn’t decay on the track, nor when I sit up and do intervals. Only when I do TT intervals.
I’m not an expert, but if you can complete the set but see that as your data point…I’d also say the resistance or measuring of power is off the longer the workout goes. Or your HR strap or monitor is wonky. There’s bad data or bad trainer control somewhere.
HR is going to drift up over time with each set.
No giggling at the data…but notice for these workouts the drift in HR with each set:
3x10:
https://www.strava.com/activities/2181861970
2 1/2 min and 1:1 intervals:
https://www.strava.com/activities/2206466606
3x5min:
https://www.strava.com/.../2215052556/analysis
A road race “opener” workout of 1:1’s:
https://www.strava.com/activities/2277152325
All those show the drift up over time. If the HR depresses with sets, then you won’t be able to finish if it’s actually fatigue. In my uneducated opinion.
This is how my heart rate normally works. And still does most of the time.
10-min long intervals are supposed to be done at 100-105% FTP. Doing them less than 100% FTP will decrease their effectiveness.
Thanks for the advice. Had I wanted coaching advice I would have asked. But to repay you your kindness: Try googling Kristian Blummenfelt, Gustav Iden, Casper Stornes or Arild Tveiten. Try to read up on how they work out and check out who has the 3 fastest time through history in 70.3 racing. I feel more confident following Arilds philosophy than yours
