Well, my comeback is being held up by a corrosion problem. The original headset expander thingy that goes in the top of the steerer tube on my Serios got corroded enough that I can’t clamp the proprietary stem without a little bit of slop at the fork/frame interface. I need a new one but I don’t know the name of the part. It’s:
- 1-1/8 steerer tube
- the expander I have uses a bolt with a 6mm Allen head to expand the plug
- a 5mm Allen bolt screws into the 6mm bolt head to pull the stem down onto the top of the fork
Do all expander woirk this way with 2 bolts, or is this special this kind of proprietary stem? What should I buy?
(Ok this got ramble-y but do you see my problem?)
Thanks,
Bigshoes
