I agree with most of what you’re saying here…
Keep in mind that I already did get fit on day 1 and as I stated, it gave me a really good baseline.
But getting fit “1 time” will never work. It takes constant tweaks to reach optimal performance. These tweaks need to occur incrementally and over time so it’s really not practical to run back to the bike fitter every time you want to move something a hair this way or that way.
I got fitted at the start of the spring, and I’m thinking it’s time for a tweak. But I’m going right back to my fitter so that he can keep track of what’s happening. I also want to make sure my position is recorded.
Usually, if you got a proper fit with a good bike fitter, tweaks are not going to cost you anywhere near the same as a full fit. Many of the best bike fitters would rather have you come in for free than have you tweak your own position.
View it as being under the care of a doctor who wants to monitor your progress.
So I don’t see this as crowdsourcing a fitting, I look at a forum like Slowtwitch as valuable source of collective knowledge that can be shared to the benefit of everyone. I really don’t think there’s 1 expert smarter than a collection of experts just as there is no “1 fit” for all people. A baseline fit is only a starting point and there are many opinions about how to best fit a person to a bike.
It’s getting better and better out there. Good fitters are easier to find, and their methodologies are starting to converge to a standard process. I like what I’m seeing from the better fitters.
All things have cause and effect and I like to understand what’s happening when I adjust 1 way versus another i.e. lower position for less drag but at the expense of power or at the expense of hamstring fatigue, or at the expense of??? etc., etc.
Do you know your joint angles, and where they sit in the normal ranges? What’s your “knee forward of foot”, and what is your range of hip angle? Where do you have some play to move things around? Are you maxxed out on any of the joint angles?
Maybe my question and knowledge base are too basic but I think it helps people (it does for me) to better understand the basics of what is happening as they change things around on their bike.
So while I agree with you that a good fitting is a great starting point, I think you have a depth of knowledge that could be shared a bit to help out the less experienced like me and many others in a way that simply provides a better understanding of the basic dynamics.
Well, that’s what I’m trying to do. When I needed a fit, I went to an expert. He took good care of me. And I will defer to his judgement, as I would to any person who’s spent time and money learning something better than I ever could.
The advice you might get from the ST crowd might be amazing or it might be total crap. You won’t always be able to know which of those it is.
One last comment. The myths that have been shattered on Slowtwitch are still being spread by 90%+ of the bike shops. I never correct these folks but it seems like “rotating mass” and cow tipping are destined to spouted as truisms for all of eternity.
Haha… How about “standover height”?
Yes, good point, we’re indeed lucky to have Slowtwitch.
Thanks, Dan, if you’re listening out there!
