What are options for power meters besides the Stages Power meter with GRX? I like the Quarq D Zero that i use on my rode bike but its not compatible.
Any suggestion?
Thanks
David
Any suggestion?
Thanks
David
Any suggestion?
Thanks
David
I assume you want to keep the sub-compact gearing? If so, there are not a lot of crank-based options, yet, and none for 24mm Hollowtech bottom brackets that I’m aware if. If your bottom bracket shell supports 30mm axles, there’s the FSA Powerbox Super Compact (48/32 or 46/30) which is a Power2Max derivative. Not sure what the chainline is with the Powerbox; if it’s “standard road;” you might need a regular road FD. There’s also the Rotor 2InPower DM which has 48/32 or 48/30 chain ring combos. That one definitely has “standard road” chainline.
What about the new Rotor PM?
The new Rotor InSpider has a 110 bcd, and the smallest offered chain ring is 34t.
Best bet is probably favero assioma pedals with the xpeedo pedal body mod. I believe power2max is working on something compatible, but no actual news on that yet.
Any suggestion?
Thanks
David
Not compatible with GRX you mean?
There are no power meters that are going to retro-fit onto that crank.
Therefore, if you are purchasing a new meter, I recommend that you stick within brand across your bikes to hopefully increase consistency.
Best bet is probably favero assioma pedals with the xpeedo pedal body mod. **I believe power2max is working on something **compatible, but no actual news on that yet.
Power2Max has had dual BCD PM spiders for mountain bike cranks for a while, and makes the PM spider for the FSA Powerbox Supercompact, which has a 120/90 dual BCD. Not sure why they haven’t brought a similar option to any of their own-brand road spiders. Maybe their deal with FSA gave FSA the exclusive market for anything below compact gearing for a period of time?
