Looking for something that rolls fast on smooth hardpack and road but has grip in corners.
I’ve run Specialized Sawtooth 42 and been very happy with it’s on road and off but find it loose in corners.
Thinking I want either Specialized Pathfinder Pro 38 or Challenge Gravel Grinder 38.
Anyone have opinion on these, another one in this category or if I’m chasing the wrong thing here?
Challenge is super light and rolls fast from what I’ve seen online. The sawtooth rolls really well and assume pathfinder will be similar but bit heavier than the challenge.
I know tri and road tires. Gravel still lots unknown!
Even though it has “knobs” in the center, I’d suggest the Continental Terra Speed.
Although listed as 40C, it actually measures more like 38mm, even on wide-ish rims, and rolls faster on hardpack and pavement than pretty much EVERY tire with a smooth, or file center and side tread, with the exception of the Challenge Gravel Grinder Pro (w/latex tubes) and the Challenge Gravel Grinder HTLR (Handmade, Tubeless Ready) which are both 36C, but are only 1W faster per pair of tires at 30kph. That said, those 2 Challenge tires are nearly 2X the cost of the Terra Speeds. The Terra Speeds are a MUCH better tire in the dirt overall IMHO, too. Think of it this way…you get a tire that rolls as fast as a “smooth” Rene Herse (Compass) Snoqualmie Pass 44C (regular casing) on the pavement, yet has great knob coverage for not only cornering off-road, but braking and traction too. It’s hard not to like that combo.
If the Gravel Grinder you mention above is the TLR model, that’s significantly slower than the tires I mention in the paragraph above, at ~6W per pair slower at 30kph on pavement.
I’ve no idea about the Pathfinders…but I haven’t heard of anyone saying they’re exceptionally fast.
All info found here: https://bikeblather.blogspot.com/2020/04/some-additions-to-gravel-tire-list.html
and here: https://bikeblather.blogspot.com/2020/02/time-to-share-some-gravel-fun.html
