New to the pool and could use a recommendation or two to try out. The sensation of the eyelashes rubbing on the lens is annoying enough, but the oil/smudges that rapidly build up are even worse. Any help much appreciated.
Not sure how long your lashes are compared to mine, but I find the Aquasphere Kaiman good.
As always the answer to goggle questions:
Or Aquasphere Kayenne might work. I use these because I don’t like the small goggles that feel like they’re sucking my eye balls out.
I’ve had good luck with the old Swedish goggles too. Several others I’ve tried have not given enough room for that uncomfortable brush against the lenses.
To give you an idea, got a pair of speedo swedish goggles in the mail yesterday (actually 4 due to a mistake by amazon sending two 2-packs) and they prob need to have about 4-5mm more depth for full lash-clearance.
Thanks for the suggestions everyone, will prob have this figured out soon after trying a few more of what’s been mentioned.
Maybe something like the Aquasphere Vista, if you are really struggling.
IIRC the speedo knockoffs are a bit shallower than the original Malmsten ones - good luck!
I have very long eyelashes (naturally 😅). I use Zoggs predator flex and find these to be perfect.
+1. I’ve fairly long eye lashes (the girls are all envious 😎) . I too find no problem with Zoggs Predator Flex goggles.
(I have difficulties with many sun glasses contacting them which gets annoying and uncomfortable).
Had a swimmer at the pool recommend using eyelash curler before swimming. Haven’t tried it as my current goggles (speedo speed sockets) work for me.
For what it’s worth I found the Aqua Sphere Kaiman too shallow for my lashes. 😊
Same here. I use Barracuda Ultimate with no issues. They have been hard to find from time to time.
