I just bought the Giro Air Attack. It is my first “aero helmet”.
I would like to know from people who have used it in: ¿did you notice any significant time or speed improvements due to aerodynamics?
Do they still throw-in the free salad tongs?
Significant? Not that I can directly attribute to the helmet.
I’ve owned a few aero helmets over the years and I’ve never noticed anything dramatic between all of them. Over a standard road helmet, sure…but it’s not going to knock 45 minutes off your IM bike.
I’ve owned 2 air attacks (both shields). I recently had the first one save my head in a wreck and didn’t hesitate to buy a 2nd one right away.
My reasons for purchasing were (in no particular order)
Hope my .02 helps
Thanks. It is pretty clear that a helmet won’t save you 45 minutes on the bike leg (english is my second language).
But compared to a standard road helmet, it is safe to say that one could expect to see some improvement.
Lots of opinions on aero helmets. Theoretically any of them should improve your time over a “Standard” helmet. The variables in play are many. i.e. does it fit? what is your head position? Do you get hot in it?
End of the day - Pick a helmet that keeps your head safe, works for you, and has some data showing it can at least be somewhat aero.
Love mine. I’ve found it’s probably worth a minute or two over 56 miles vs. my standard road helmet. Too many variables & too small of a sample size to say definitively in my case, but seems to be in line with published data from other manufactures of their aero helmets vs road. And since i’m fairly garbage at holding good form with my head/ neck, I don’t have to worry about a big tail fin hanging up in the air.
If it’s hot, I wear my road helmet. The air attack isn’t super vented, so the physiological cost of running hot on the bike outweighs the extra minute or two for me since I have to run. I’ve also found on extremely humid days, the shield fogs up.
I have one. I also have an aero helmet.
I don’t consider the AA an aero helmet. Better than a pure road helmet? Probably.
I bought an Air Attack shield last year to replace a Louis Garneau Crono. I would guess both are on the low-end of aerodynamics. The air attack is definitely faster for me than the crono because, even though I have a large head, I can fit into a size medium Air Attack - whereas I am a size large in almost every other helmet. The medium is much smaller than the large, and thus a reduced CdA. I’m also pretty happy with the shield / visor instead of glasses.
Nothing significant…I was in an accident and it saved me from potentially killing myself… so as a helmet it works in that regard. It doesn’t rate well against current “aero helmets”… but we’re probably splitting hairs.
I really liked the integrated shield and replaced it with a Bell Pro Star Shield.
While helmets test very differently on different riders, it will depend on the standard road helmet. There was a test about 2 years ago on bikrerumor (I think). The Evade was the best of the Aero Road group and the Air Attack was the worst. It was also beaten by a couple of standard road helmets. I think the Prevail beat it, but I am old and am not confident in my memory on that.
Aero road helmets tunnel and road tested: http://www.bikeradar.com/us/road/gear/article/best-aero-road-helmets-tunnel-and-road-tested-44719/
Video from the link above: https://www.youtube.com/watch?v=Bs5KtgdJmso
