Garmin Varia not fully charging. Any solutions?
My Varia (older model) suddenly decided to stop charging past around 15%. Anybody have ideas on how to fix it? Run it all the way down? A reset? Firmware update? Or is the thing toast?
Thanks for all the great responses!
There aren’t really an great responses available.
Battery replacement is generally the only option when these hit EOL, and while you can source a replacement battery pretty easily, any components that might get damaged in the replacement process are difficult to find. This makes repair commercially unfeasible, and a crapshoot crossed with a PITA for a consumer.
Most folks - unfortunately - just wind up having to throw them away and replace.
I would reach out to Garmin; they’ve given some pretty significant discounts in the past for EOL equipment, particularly if you buy a lot of Garmin stuff.
Worst case is they say “no’“ and you’re back in the same boat of having to buy a new one.
try that for exchanges
Might want to try a different charging block. my Varia only charges with specific charging blocks. I suspect it needs one the can put out a little more.
It sounds obvious and maybe you already tried, but cleaning out the USB port solved charging issues on both of our Varias.
