I’m hoping Someone will know an answer to this question or be able to do a quick test to find out for me. On the newer garmin watchs, when creating a custom strength workout in connect and you include both reps and weight can you edit those reps and weight when actually performing the workout on the watch?
Example: I create my workout in connect of three sets of squats, 15 reps per set using 100 lbs. I download this to my garmin watch and go workout. After my first set I only get 12 reps, so my second set use 90 lbs instead of 100 and get my 15 reps. Can I record those differences from the prescribed workout on the garmin watch and have it write back to connect basically as a lifting log? I done care much about the auto rep counting, although that would be great, just manual rep and weight entry would be good.
