World is coming to an end for me. I did update my TP password yesterday, but Google doesn’t make it look like I need to do anything to keep the connection.
Garmin just running slow, or did I break something?
No problem yesterday. My workouts aren’t syncing yet today. Can always do a manual download/upload but I figure it’ll be fixed pretty soon.
Mine took an hour today.
Mine just uploaded. The earth is spinning again.
Mine is still down. Wasted a lot of time today trying to get this to work. I assumed it was something wrong with my apps. Grr…
Been there. Done that………….
Thought the same, but I was super busy so when I finally had time to come back to it, was there!
I just came to the board to complaint about this. It sounds like it’s a system wide problem.
Mine took about 2 hours today but eventually it got there. It went to Strava immediately. This has happened a few times for me.
Same. My swim synced after about 2 hours. My bike and run his afternoon haven’t synced yet.
Likewise Strava synced immediately. Based on that, I assume it is a TP problem.
Happened to me too today. Went into my Garmin Connect it TP is no longer listed under 3rd party apps? I hope this is just a glitch…
Everything of mine has now synced. Took about 2 hours each: swim, bike, run.
I’m having auto sync issues again from Garmin Connect to Training Peaks. Garmin Connect to Strava sync’ing fine. Anyone else seeing this?
Thanks!
Happening again today. Anyone else?
Just got done with a run and it sync’d fine for me. Both to Traingpeaks and to Strava.
If your phone updated recently to IOS 13 check out Garmin Support Center for tips on how to fix it.
Synced to Strava, but not TP. Did not update IOS
I’ve also made no changes to my phone or devices. Workouts from Sunday transferred (2 different devices), but the one from Saturday still hasn’t (same device used on Sunday).
I always find this game so tiring.
Yep, synced to Strava but not TP. It’s been solid for a while though.
When mine doesn’t sync properly, I find it sometimes helps to disconnect/reconnect your TP and Garmin accounts.
The other option if that fails is to manually download the .FIT file from Garmin Connect and then manually upload it to TP (I have had to do this a couple times when method 1 has failed in the past). Also, if your workout was on Zwift the .FIT file will already be on your computer (in a file within the Zwift folder).
