Garmin Connect - Heart Rate Not Showing
Hi, does anyone have any suggestions? I looked online but no one seems to have a definitive fix. My watch shows my heart rate, but in Garmin connect its not logging it at all. Also, my REM sleep is blank.
Cam
Cam
more info may help get you a reasoned answer? what watch, for starters. Also has it ever sent the data to connect in past or is this something new?. Does the watch show up on connect? probably someone who has your model might then be able to assist you.
Thanks.
Garmin Vivoactive 3
Watch shows up on Connect and no issues at all. The heart rate field shows up but is blank. Some suggested that i remove the heart rate field through “EDIT MY DAY” and then add it back. i did that but no luck.
Do you have the setting to “broadcast”? I dont know why that might matter, but try it.
I do not have that model but my Vivoactive HR needs to be paired with my phone for the data to transfer to connect. It looses the connection form time to time as does my 520+ and I have to manually cause it to sync from the phone connect app.
