Back in June I bought a new Garmin 965 watch. I almost immediately had issues with the strap becoming unfastened (still stays “strapped” but the piece you tuck the extra strap under comes undone) rather easily. Happens mainly when swimming (the water forced the strap to come loose from the slider) and when running (the flat catches a shirt or part of the jacket and comes loose).
I’ve had mine for a few weeks, have done a few pool swims and several runs, no issues like that. Do you have huge wrists and thus not much of the strap feeding through the loop??
I bounce between the 9th and 10th outlet leaving me about 11 to 12 loose. Just curious as I’m probably going to get a new band but didn’t want to get the same one. That loop thing just seems very loose
FR955, but yes same thing. I’ve just got used to that now.
Also 9th hole (sometimes 8th if swimming). 9th is comfortable but lets that retaining loop move a bit. 8th is too tight for 24/7 wear and I get a rash under the HR sensor.
Has anyone else had issues with this?Ditto FuzzyRunner above. There is a pin on the underside of the loop that secures the end of the band flap. I’m willing to gamble yours has turned to the underside of the watch band.
I also purchased a 22 quick release strap. While the replacement strap Garmin sent me is better than the original that came with it. The Quick Release 22 is far better. So if you were having the issue I was having, I’d just get a Quick Release strap.
Am using a Wahoo Rival strap on mine, fits fine and much nicer quality than the Garmin. Has 2 retaining loops so no issues with strap coming loose or flapping around.
