I recently purchased a speed/cadence sensor for my SC7.0. After my first ride with the sensor paired with my Garmin 910 I tried to upload to garmin connect. When I did it appeared that the GPS did not track my route it only picked up my speed from the sensor. Is this a setting that I need to change to have both?
looks like your GPS wasn’t on? If GPS is on and duotrap are connected, it’ll use the duotap to record speed/distance since it is more correct, but will still map the route using the GPS.
