Hi, I’m thinking of getting a forerunner to use as a poorman’s powermeter. I’m wondering if I can program it to set a virtual pacer to do a workout in this format:
20min@ XXmph (warmup)
20min@ YYmph (Threshold)
5min@ XXmph (recovery
and a cooldown.
I already do 2x20’s on the trainer and am basing my efforts on it’s power profile. I have been using the KurtKinetic PC (a really poorman’s powermeter) and have done ok with the calculated measurements off the trainer. I like the idea of using a Garmin 305 indoors with the speed sensor and both recording the data and having a programmed pacer. I know I could do a workout and use it on the garmin as a pacer, but what I would like is to punch in the exact numbers so my pacer doesn’t have any variety.
Anyone doing this or know if it’s possible? Thanks.
You can create custom interval workouts, but they are based on time and distance, not speed. So you would need to calculate the distance covered from your desired speed.
If you do not all ready own a Garmin 305, I would suggest going to the Garmin website and reading the owners manual to confirm this prior to making a purchase.
Thanks for the response. A couple things weren’t clear from the manual.
Under “Intervals” it looks like you can do time OR distance, but not both.
Under “Advanced Workouts” it does look like you can set a goal, but isn’t clear on how to use the pacer with the it (or if this happens automatically.) Have you used the pacer function?
Good catch… It has been a year or so since I used the interval feature, and I have never used the pacer feature. But now that you mention it I remember the intervals were not time AND distance, but time OR distance.
So I will let someone else who uses the pacer try to answer.
I’ve only used the custom workout thing for running, but in that I could set time and pace i.e. “run between pace A and pace B for X minutes” - I think it would do what you need. I don’t have the unit here to verify it, but I think it will…
If I find out more when I get home, I’ll post it here!
Also note - some folks find the altitude to be flaky on the device - and it is. But motionbased - which is free - will correct all of that for you. I recently did a ride where the watch said I climbed 4500 feet when I had actually climbed 5500.
Thanks for the tip on motionbased. Yeah, I know I’m giving up the better altimeter if I go with the forerunner over the edge, but it seems like for running (and cheapness) the forerunner will work better all around.
Interesting. How does motionbased correct the altitude data?
btw I’ve pulled some files for IM courses from motion based and they still give wildly varying ascents. Does this correction you speak of happen automatically or does the user need to correct when they upload the data.
