FSA Gossamer pro 50/34t -> 52/36
I bought a cannondale cadd10 105 brand new a year ago (shimano cassette 12-27 10spd, FSA compact chainring gossamer pro 50/34 110BCD). Very happy with the bike except the compact chainring. Thinking about going for mid-compact (52/36t). Can I just replace the chainrings without anything else? Or do I have to change the cassette and the chain as well?
FSA website has super type chainrings at 52/36 @ 110mm BCD. It is easy to find super 52 on the market but super 36 inner chainring seems very rear. A lot of pro 36t. So can I put super 52/pro 36 together? I barely use a smaller ring since it’s flat as a pancake here.
53/39 comes only with 130mm bcd. That would trigger more replacements. That’s why I am shy away from it.
Thanks
I have an 110 BCD FSA gossamer crank and swap between between 50/46/36/34 chainrings on a regular basis without any problem, the front derailleur just needs minor adjustments. My main reason for swamping rings though is alternating the bike between a pure cross set-up (46/36 12-32) where I want to select a front ring and leave it there the whole race and amore of a road friendly set-up (50-34 11-25/28) where I have shift the front whenever I need to. I find the cassette makes much more of a gearing difference that the front rings and while I would have to double check I think dropping to an 11 on the back will be a bigger change than moving to a 52 on the front. You may also find it cheaper to pick up a 11-25 shimano casesette than new chain rings and it takes a decent hill to need a smaller option than 34X25.
It’s fine. You can also go 52/38. I’d go Praxis for chainrings though.
thanks guys. I am going to do it !
Second the Praxis rings. Front shifting is very good with Praxis’ shifting ramps.
Alternatively, take the opportunity to switch to a 105 chainset with a semi compact chainring setup. A new 105 chainset would nearly be offset against the cost of new chainrings.
105 chainset is not compatible with BB30. Right?
No, different spindle diameter. Do you have BB30? If so, swap just the rings or budget for a Rotor, Enduro TorqueTite or Praxis Works BB3024.
If you want you can find even a 54 a 110 bcd which works with the 38
