Bought new over the winter and don’t use the bike that it is attached to much. It looks as good as the day I bought it. Latest Generation and firmware. Comes with all original packaging and paper work. Bluetooth and ant+ $550.00 shipped to the U.S.
Orig cost was $629.00 plus tax
From the stages website:
The Stages Power meter is built to the proprietary Stages Power carbon left crank arm. The full carbon fiber Stages Power meter and crank arm is compatible with many SRAM GXP road cranks.
The new Stages Power meter is slimmer, and up to 28-percent lower profile than our original meter. It’s sleeker by way of a 17-percent reduction in frontal area, and we’ve also made it stronger. The new housing design increases the strength of the battery door and housing connection by 200-percent over the previous design.
SPECIFICATIONS
Accuracy: ± 2% Power meter housing: new low profile design, with new door interfaceWeight: Only adds 20g to base crank armBattery Life: 200+ hours (coin cell: CR2032)Power range (Watts): 0 to 2500Cadence range (rpm): 20-220Water resistance rating: IPX7Frame Compatibility: Most frames, see fit guide in our Support sectionDevice Compatibility: ANT+, Bluetooth Smart Ready Software Compatibility: Training Peaks, Strava, Garmin Training Center and others
ADDITIONAL FEATURES
Tool free battery replacementActive temperature compensationAccelerometer based cadence measurementWireless firmware upgrades
