The listing says it all.
Bought new in August of 2012, I have ridden maybe 1500 miles on this crank.
It’s light, it’s stiff, easy to install, and compatible with ANT+ devices. I had it paired with a Garmin and never had any problems with it.
Life, a.k.a. career and family, have put a damper on racing. I’m just not riding enough to justify this awesome crank. Maybe again in a couple of years, but not now. In the mean time, the crank deserves a loving home that will actually use it.
Specs:
Since it’s on a 3D+ crank, it fits BB30 bottom brackets. I know that it will fit the newer Cervelo. Make sure you bike is compatible with the crank.
Arm length is 170mm.
The spider is a 110 BCD. With Rotor, this doesn’t limit your chain ring size. Right now I have a 52 tooth big ring and a 36 tooth smaller ring. Right in the middle of the standard and compact range. Plus with the 110 BCD, you could actually put this on your cross bike fitted with the appropriate rings.
Both rings are Rotor’s unique Q rings, and the big ring is the solid, TT style.
These cranks are not brand new, and do show some scratches, as to be expected. With that being said, they are still in great shape.
The price: $1150, plus shipping.
If you have any questions let me know.
Pics:
http://i40.tinypic.com/65d6r6.jpg
http://i39.tinypic.com/2dkzm1g.jpg
