FS: Mavic Ksyrium Elite Wheels - Black 2011
Selling this set of wheels as they came OEM on a new bike and as much as I want to keep them I can’t justify another set of wheels.
Retail MSRP on the I believe is about $625 or so. Yours for $395 shipped. They have never been ridden, no tires or cassette included. Freehub is fitted for Shimano/Sram.
http://i52.tinypic.com/kb3xp0.jpg]
Here are the specs on the wheels:
Rely on the proven Mavic quality:
• Rim resistance : Maxtal, SUP welding, Fore drilling
• High quality adjustable cartridge bearings:
• QRM+
Weight:
• Weight (ED10): 1550 grams per pair
• Front wheel: 675 grams
• Rear wheel: 875 grams
Rims:
• Colour: black
• Fore
• Height: front 22 mm, rear 25 mm asymmetrical
• Material: Maxtal
• SUP
• UB Control
• Valve hole diameter: 6.5 mm
• Weight reduction: ISM
Spokes:
• Colour: black
• Count: front 18, rear 20
• Lacing: front radial, rear Isopulse
• Material: stainless steel
• Nipples: integrated M7 aluminium with dry thread lock
• Shape: straight pull, bladed
Hubs:
• Front and rear axle material: aluminium
• Front and rear bodies: aluminium
• Front axle size: 9x100
• FTS-L, steel
• QRM+
• Rear axle size: 9,5x130
Technologies:
• Fore: Only one of the 2 rim wall is “drilled”. The rim is 4 times more resistant to fatigue stress.
• 20% increase in the rim rigidity to transfer all of your energy to the ground.
• FTS-L: Force Transfer System Light The reinforcement of the key transmission components.
o Lighter hub
o Stronger hub
o Better torque transmission
• ISM: Inter Spoke Milling: Lighter rim and equal rigidity is the magic equation to reduce inertia and to free extra power for climbing. A Mavic patented exclusive concept (US 6 402 256).
• Isopulse: This spoke lacing design and wheel building brings better wheel stability and a crystal clear transmission of energy thanks to a better spoke tension balance between left and right flanges.
• Maxtal: Exclusive to Mavic. An aluminium alloy that is 30% more resistant than a 6106 alloy, for lighter and stronger rims.
• QRM+ Qualité de Roulements Mavic + (Mavic bearings quality +): Our most demanding level. Those cartridge bearings are of course double sealled with C3 internal clearance, and topped with a micro-adjustability system, allowing you to quickly adjust your wheels according to performance goals: precision ““free”” adjustment for maximum fluidity, or perfect high precision setting for all-weather rides.
• SUP: Soudé Usiné Process - A welded and milled rim joint is extremely strong, eliminates shuddering when braking, and offers superior wheel balance.
• UB Control: Usiné Brut Control The braking surfaces are milled to improve braking friction and eliminate shuddering.
Compatibility:
• ED10 or M10
• ETRTO size: 622x15C
• Recommended tire sizes: 19 to 28 mm
• Tire: clincher
Do you still have the wheels?
Wheel are sold - thanks!
