FS: Bontrager Aeolus Elite 35 TLR disc wheels
Price drop - $550 plus shipping from 23455. That’s 50% off retail for essentially new carbon tubeless wheels.
Got a shit offer from Pros Closet - you match it and they are yours. $475 plus shipping.
I’ve been looking for some carbon wheels for my Trek Checkpoint which has Shimano. Would your wheels work?
I believe so, with a little bit of work - as long as you need disc wheels with 12X100mm and 12X142mm thru axles. These wheels have the newer XD-R freehub on the rear for SRAM 12pd cassettes. Trek also sells these wheels with a standard Shimano/SRAM 10/11spd freehub so you should be able to swap it over easily. I’m guessing the new freehub body is about $50 based on doing something similar to a different set of wheels recently. I actually posted a question about this yesterday when someone else inquired but it doesn’t have any responses.
Thanks. I’ll look into it today. Also see the inner rim is 19.5 mm. Need to see what max tire capability is.
Sent you a pm wondering if came through. It looks like switching the freebody would be about $100 if I can get the correct one Plus $60 in labor. Add that with shipping to my zip (97213) is getting up there. Do have any photos. I can pm you my e-mail.
Barb
I’m not seeing any messages.
It’s a very simple process and should only take about 5min to swap. It’s simple enough to do yourself if you are at all mechanically inclined.
