For sale is a 2025 Specialized Crux DSW frameset, $1500. Size is 58cm, fits roughly 6’0"-6’3" height. Color is called “Gloss Amber Glow / Vivid Pink / Metallic Midnight Shadow / Speckle.”
It’s in excellent/like-new condition. I built it up, it has about 6 miles of test-riding, and then disassembled it to go in a different direction. The only wear I can see is on the back of the seat tube. I had the area wrapped in 3M clear bra tape, and when I peeled it off, it left two of the orange stripes with a slight vertical seam, and pulled a fleck of orange paint off. I took a pic, but it’s pretty slight so I don’t know if it’ll show up.
Other parts of the frame are still wrapped in protective tape. Brake mounts have been faced. Steerer tube is cut to leave 75mm of steerer above the headset cap. Includes all the doodads it came with to build it up. Frame was ordered 6/11/24, so second owner’s factory warranty is good through 6/11/26.
Frame highlights:
-Alloy frame
-Full carbon fork, tapered 1 1/8”-1 1/2”
-47mm tire clearance
-UDH derailleur hanger
-68mm BSA threaded bottom bracket
-12x100 & 12x142 thru axles
-Flat mount disc brakes
-27.2 seatpost
Full frame details and geometry: Crux DSW Frameset
