Finished up another project build and decided to stick with my other road bikes. So this one is up for sale.
The build is a lightly used 2020 Specialized Tarmac Disc Pro frameset with a brand new SRAM AXS group and new Roval CL50 tubeless/clincher wheels. This is the SL6 10r carbon model, just one step below the S-Works, differing only in the 10r vs 11r carbon layup. 56cm in a cool bluish color. It looks darker inside, but under the lights or sun it changes and is more of a blue. No issues with the frame except some rub on the outside non-drive side where the chain and seat stays meet. Steerer has a 10mm spacer installed. Saddle is a little high in the pictures, around 77cm.
Build group is all brand new SRAM AXS. Shifters are RED AXS, Force AXS FD, Force AXS RD, Force AXS DUB chainset 172.5 48/35, Force AXS XG-1270 10-33 cassette and Force AXS flattop chain. Shifters are mechanical braking allowing for easier setup and on the road maintenance, plus you get a much better feeling lever vs. the bulky hydro levers.
Seatpost is lightly used as the frame and is mated to a Specialized Power 143mm saddle. Saddle was bought here lightly used with some scuff marks on the left back wing. Bars are lightly used S-Works Aerofly 40cm mated to a new Pro Vibe 110mm -10d stem. Tape is new Fizik Vento Solocush Tacky.
The bike stops with the latest and greatest Juin Tech GT-F calipers. These are the 4 piston design and are brand new. Brand new SRAM Centerline X two piece 160mm rotors front/rear. Wheels are brand new Roval CL50 tubeless clinchers. 12mm front/rear with XDR driver. Front wheel has a Corsa Control v2 30mm tubeless tire installed for sizing purposes. Picture shows clearance at the fork. No issues! Rear is setup tubeless. I am including a new set of Corsa Control 30mm tanwall non-tubeless tires or you can swap and have the new 30mm tubeless all black versions instead. They have some sealant residue, but are brand new.
As built, without the one tire, chain or pedals it comes out to 15# 6oz. Only selling because there are other “road” priorities. Let me know if you have any questions. Currently these are $6800 on the Specialized site.
Asking $4500 plus actual shipping and any fees.
