FS: 2018 Specialized Epic HT 29er Medium 17.7 lb!
For sale is a 2018 S-works Epic Hardtail World Cup. It is fully loaded and light, 17.7lbs with a SRM Powermeter. It is in very good condition and is a medium.
Possibly the perfect X Terra race bike!
*** Can replace SRM cranks with brand new XTR 12-speed cranks for $5000***
Here is the build:
FRAME: MEDIUM / FACT 12m, full carbon frame w/ unique S-Works lay-up, XC Geometry, internal split-housing cable routing, triangulated post-mount 160mm brake
FORK : Fox Factory Step Cast 32 4FIT 100mm
WHEELS: Roval Control SL 29 / Boost 110/15 148/12
TIRES: Schwable Racing Rays / Ralphs
HEADSET: Specialized Standard
STEM: Specialized S-Works SL, 6-degree rise, titanium hardware, 31.8mm clamp
HANDLEBARS: Darimo MTB handlebar 680mm
GRIPS: OSI
SEATPOST : Sworks carbon 27.2mm / 400mm
SADDLE: Not included
CRANKS : SRM Origin MTB rechargable / 34T Wolftooth chainring / Pedal inserts included but not pictured
BB: Kogel PF
PEDALS: Not included
REAR DER.: XTR Long Cage Rear Derailleur 12-speed
CASSETTE : XTR 10-51 12 speed
BRAKES : SHIMANO XTR Race Hydraulic Disc Brake Lever I-SPEC EV Clamp Band/ XTR 2-piston calipers
SHIFTER: XTR 12-speed shifter
CHAIN: XTR 12 Speed Chain
The bike is in very good condition with some nicks and rubs. All is cosmetic and not obvious.
$5500 PP f/f gets it shipped via bike flight with $200 insurance to you in the CONUS. I will give you a better deal if you pick up local in Fairfax California.
https://i.imgur.com/9iWtLGJ.jpg
https://i.imgur.com/l5OJN6A.jpg
https://i.imgur.com/pBbvq3b.jpg
https://i.imgur.com/Z3E5Vpt.jpg
https://i.imgur.com/ZP2lIsB.jpg
https://i.imgur.com/f524Ylq.jpg
https://i.imgur.com/v3tYOT3.jpg
https://i.imgur.com/uZcUUwx.jpg
https://i.imgur.com/kvcti9P.jpg
https://i.imgur.com/puOG4xR.jpg
https://i.imgur.com/XRMB1IW.jpg
(http://i.imgur.com/3MjsJ3E.jpg
(http://i.imgur.com/qylNnV8.jpg
(http://i.imgur.com/261W4Rv.jpg
(http://i.imgur.com/6rQdOcj.jpg
