Looking at selling my mountain bike to lighten the load for an upcoming move.
Bike is in wonderful condition and was clear protective wrap on much of the frame. However, it is used and there are some minor marks but nothing that wouldn’t happen through normal riding. The brake levers have a few marks as well. Perfect working order and the rear shock was just sent back to fox for rebuild.
Asking $3100 shipped
Details:
FRAME
FACT 9m carbon, EVO 650b geometry, FACT IS construction, FACT carbon front triangle, M5 alloy rear triangle, tapered headtube, carbon PF30 BB, ISCG ’05, internal Command Post IR routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm travel
** SWAT**
Bottle cage w/ SWAT Technology
** REAR SHOCK**
Custom FOX Float CTD Factory w/ AUTOSAG and Boost Valve, Kashima coating, Climb, Trail, Descend settings and rebound adjust, 194x51mm
** FORK**
RockShox Pike RC 650b, Solo Air spring, tapered alloy steerer, w/ compression, rebound adjust, 15mm thru-axle, 150mm travel
** HEADSET**
1-1/8" and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
** STEM**
Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise
** HANDLEBARS**
Specialized All-Mountain, low rise bar, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 31.8mm
** GRIPS**
Specialized Sip Grip, light lock-on, half-waffle
** FRONT BRAKE**
Shimano XT BR-M785, hydraulic disc, Ice Tech metallic pads, 200mm rotor
REAR BRAKE
Shimano XT BR-M785, hydraulic disc, Ice Tech metallic pads, 180mm rotor
** BRAKE LEVERS**
Shimano XT BL-M785, hydraulic, alloy lever
** REAR DERAILLEUR**
SRAM X01, 11-speed, carbon cage
** SHIFT LEVERS**
SRAM X01, 11-speed, trigger
** CASSETTE**
SRAM XG-1195, 11-speed, 10-42
** CHAIN**
SRAM PC-X1, 11-speed
** CRANKSET**
Custom SRAM S-2200, carbon, PF30 spindle, 30T, 94mm BCD spider
** BOTTOM BRACKET**
SRAM, PF30, OS press-in bearings, sealed cartridge
** RIMS**
Roval Traverse 650b, alloy disc, 24mm wide, 27/32h
** FRONT HUB**
Roval Traverse 650b, 15/20mm thru-axle, 24h
** REAR HUB**
Roval Traverse 650b 142+, XX1 driver body, 12mm thru-axle, 32h
SPOKES
DT Swiss Super Comp, stainless, 2.0/1.65/1.8mm
** FRONT TIRE**
Bontrager XR4 Team issue 27.5x2.35
** REAR TIRE**
Nobby Nic EVO pacestar 27.5x2.25
** SADDLE**
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
** SEATPOST**
Command Post IR, 3-position height adjustable, alien head design, bottom mount cable routing, w/ remote adjust standard lever, 30.9mm, 125mm travel
team issue front both set up tubeless.
