Freehub Removal - Need help
How do I remove this freehub? It is from a 2012 Specialized Stumpjumper Comp 29. It’s the stock Roval wheel with Sram X9. Which tool, specifically, do I need. I’m not asking for general advice on freehub removal but for this specific instance. Thanks.
http://i33.tinypic.com/5bofg2.jpg
http://www.parktool.com/blog/repair-help/freehub-service
http://www.specialized.com/bc/microsite/roval/
Yup, found both of those links already. Thank you but they didn’t help me. I believe the video on the Roval microsite applies to their higher end wheels. If anyone knows how to do this please help. I don’t need to be pointed to links, unless that link is the specific tool that I need. Thanks.
No experience with Roval wheels, but it looks as if the DS endcap pops off and you pull the freehub off (like recent PT hubs). Do you have photos of the NDS side? It doesn’t appear as if a cone wrench/hex wrench are needed for removal. Good luck!
-Pete
P.S. For some wheels, you need an axle removal vise tool: http://www.parktool.com/product/axle-vise-av-1
This might seem really obvious - please don’t be offended but are you sure its not an allen key down the shaft?
I have Novotec/joytech hubs and they look the are similar
This is for a Zipp wheel, hope it helps.
http://www.slowtwitch.com/Tech/Hub_How-To_-_Zipp_182_3300.html
If there are no wrench flats on the axle ends, it is most likely an Allen wrench in the axle that takes it apart. Put one in each end of the axle, and twist. Hard.
Be careful when you pull the cassette body off, the pawl springs just LOVE to jump out and land in unreachable places. Not that I would know…
Pics of the opposite side, from the side and straight on, plus pic straight on of the cassettte side will help.
