I am completely fed up with having weak, injured feet. Is there really something to doing exercises such as moving marbles, coins, batteries or other such items? I just did about ten minutes of picking up size AAA batteries with my feet, moving them around from outside both feet, to back between, to outside the other foot, then repeat. I could feel some little muscles getting a bit sore. If I keep this up, can I really hope for some improved resistance to injury?
What kind of weakness/injury problems are you having?
I have PF issues as well as some issues with overpronation. Also, every now and then it seems I have acute/sharp pain just below the ankle, either inside or outside of the foot as well. It feels like something has happened (strain/sprain…)to the smaller stabilizer muslces in the foot/ankle. Basically a bunch of minor aches and pains which are not a major issue for everyday life; however, they dramatically impact being able to run when they flare up. I would like to strengthen these little muscles, so I can consistently run without being injured.
I’m also interested in any replys. I have a similar problem with off & on pain around the medial malleolus (sp?). I’ve tried exercises for the arch but to no avail. I used to do exercises with the toes (drawing up a towel with my toes) to no avail. Have done toe raises to no avail. What else is there?
And it seems there is no consensus on how to treat Plantar Faciitis. I just got back from a doctor who told me the only real treatment is to stand on a stair step to stretch it out. The day before I was talking to a gal on the team (who is also an emergency room physician) and she had someone give her a cortizone shot. My doctor says that is the last thing I should consider. This is really frustrating.
I have had this issue before and these really did wonders for me:
1- stretching my calf muscles several times a day.
2- Massaging the sole of my foot with a tennis ball, followed by a golf ball, followed by
icing it with a frozen can of soda, again at least 3 times a day.
3- dorsiflexing and relaxing my ankles while I was sitting.
4- VERY IMPORTANT: being in decent shoes and sandals with good support
(the famous german brand (Brock*) than I don’t remember is recommended)
every single seconds of the day!! seriously, in my experience even
one step barefoot is equal to one day delay in healing.
5- Some people say night splints are effective, I personally never tried them
but I can imagine how night long stretching can accelerate the healing.
6- Strengthening exercises: Picking up small objects like marbles with your foot from the floor.
7- Barefoot running on soft surfaces, should only be done after the pain subsidized.
I’ve had problems, just on my left foot, over the years (PF, shin splints). My girlfriend’s a physical therapist and suggested that I stand on one foot (the problem one) while I brush my teeth every AM and PM. It makes you work on all the intrinsic muscles of the foot to stabilize and balance. I could hardly stand on that foot and balance when I first started, but improved very quickly. Now, a couple months later, I can’t believe how much better my foot is - much stronger, no problem standing on just that foot, etc. No more PF or shin splints!
Hope that helps,
Christopher
I’d suggest you go barefoot as much as possible, do a weekly run on uneven terrain (even if it is on the grass margins next to the road) in the thinnest soled shoes you can find, like racing flats or Nike Frees. Problems like this can often be from having too much support. The success from standing on one foot brushing teeth sort of points to this. Also a bosu ball to help train the lower leg can help. Another is using stretch cords, one-legged.
Good Luck
Now my experience has been exactly the opposite of this. As long as I wore shoes with good support, my foot felt ok while I was wearing the shoes, but the PF never got better (this went on for almost 3 years). As soon as I said screw it and starting wearing loose sandals and going barefoot virtually all the time, the PF cleared up and I am now up to running 40 mpw with no PF pain.
I also find that walking on my tippy toes helps out when I have bad flare-ups (haven’t had one for 4-5 months now).
I agree with barefoot walking/running in general and I am aware of its benefits, but I think when your
plantar fascia is injured and inflammated, you should let it heal before start doing such activities. They
only aggrevate and thus postpone the healing.
It is interesting you mention “Problems like this can often be from having too much support.” The first time something like this flared up was this summer. My initial response was to simply walk around in motion control shoes absolutely as much as possible. I think this has made my feet/ankles weaker as a result. The symptoms when away; however, the cause of the problem remained (or worsened). Hopefully the preventative measures you guys mentioned will help. Thanks for the responses!
I was tempted to ask how you could make one of those (à la the flat coke question).
But actually, in all seriousness - wouldn’t the liquid expand, and break the can, if you let a full can of soda freeze?
-charles
open the can, drink it, fill three quarters of it with water, open the freezer door,
make room in the freezer’s shelf for it, put it there and make sure it is not upside down, close the freezer door, wait there for an hour (YES, you MUST stand right there!!, if you get bored, you can count your pulse in the meanwhile), open the freezer door, it’s ready to use ![]()
I’ve had similar problems. My ART guy has me stand on one foot, lift the ball of your foot up so you’re balancing on your heal. With your other leg extended in front of you, just move it from one side to the other. The small corrections will strengthen the muscles surrounding your calcaneous.
Good luck, Ian
