Fizik bar tape question
I want to try some fizik bar tape, as some people say it is pretty good in the durability and washability departments.
However, they seem to have 3 different tape surface finishes: ‘classic’, ‘soft touch’, and ‘tacky touch’. Can anyone explain the major differences and steer me toward the better ones?
thanks!
The “soft” provides a little more cushion. The “tacky” provides a little more grip when wet. The “classic” is the stuff you’re most likely used to seeing. I used the classic white. It’s durable and cleans easily with Simple Green and a Scotch Brite. @nd year old white tape will pass the “10 foot” test.
hth
i got whichever one comes in neon yellow, think its classic, man holds up amazing, easy to clean, slippery when wet though.
To make it even more confusing, they also offer all 3 finishes in 2mm and 3mm thicknesses.
Regarding the finishes, the classic is kind of like what you might find in a nice car interior - smooth, doesn’t stick to your hand, yet doesn’t have a “fuzzy” feeling to it like the soft touch. The soft touch is more of a suede feel. The tacky touch feels a bit more sticky, although not in a way that you would think you’re going to have blackened hands from it. To me it feels more like a rubber tire compound than the others do. The tacky touch is more like a golf club grip, if my memory about golf serves me well enough. I guess I would think it would be a good choice for the person who has sweaty hands and doesn’t wear cycling gloves.
If I were to take a wild guess at which was the most aerodynamic, I’d say the classic. But I have no idea. But, if I wanted safety first, I’d go with the tacky touch.
I don’t know if that helps at all - it’s hard to try to describe these different tapes objectively and without just using the same words they use to label the products!
Thanks for all of the replies. I am I pretty sure that I am going to go with the thicker tape, as it is for an off road/gravel bike. My problem was trying to figure out the best surface finish. Sometimes I ride with long-fingered MTB gloves, and their palms have been shredding my existing bar tape. So it seems that classic might be the way to go if I try the fizik tape …
