What have been your experiences if this has happened to you?
I have yet to flat a tubular in a race but was wondering what to do? I know the usual can of pitstop is a go to answer but I know this is not fool proof.
Thoughts?
just want to cross every T before my ironman
Pitstop is a 50-50 proposition, if that. If you follow the directions you are supposed to inflate then press a finger on the puncture spot for 5 minutes before continuing. You can roll a new tubular in 5 minutes and the odds of success are a great deal higher than 50-50.
I put a couple ounces of Orange Seal in my tubs. I’ve had a few punctures so far this season plus a minor sidewall cut and am still rolling with the same rubber no problem. All I did for one of the punctures was pull out the staple (or brad or whatever it was) since it was pretty big and sticking out of the tread slightly so I could grab it with my fingernails, gave the wheel a quick spin and she sealed up nice and tight right away. I topped up with some CO2 and I was on my way in no time. During a race, I’d say I could be up to speed again in less than 2 minutes with a stop for debris removal and CO2 top up. In fact, sealant might work so well you might not even notice a puncture at all if it’s small.
Yes, and MT is a very clean course and if you have any gas when you hit Chemin du Plessis you might even enjoy the scenery.
I feel sorry for those guys in Le Tour de France. All that beautiful scenery and all most of them see is the butt of the rider in front of them. Maybe you will have better luck?
glue will hold? IMMT is not that technical but it does have a few sweeping corners at speed…and a few decents where youhit 75-80kph
Yes, the tire will hold…but don’t go ripping through any turns. The descents should not be an issue by themselves, but definitely be careful on all turns.
if the tire is pre-glued as suggested, it will help in the adhesion, but since it never had a chacne to cure with the rim, the bond is nowhere near as strong as a properly glued tire. It will get you home, but don’t expect the same performance in turns.
