Fitters: Favero Assioma Duo Power Meter Pedals vs Look Keo Classic Fit question
Hi All,
I have a friend that has had knee injuries in the past and is moving to Favero Assioma Duo Power Meter Pedals from Look Keo Classic pedals. She says the cleats should be the same between the pedals, but wasn’t sure about any pedal height differences. Do you know if she would have to adjust her saddle height higher or lower, or would the top of both pedal systems be equal from the center of her crank spindle. Any guidance from the ST collective wisdom, would be appreciated.
Thanks,
Wetswimmer99
Found a couple reviews. Assioma pedal stack height is 10.5mm. Look Keo Classic is 17.5mm.
Thank you. So does this mean she would lower her seat by roughly 7.0mm?
Probably, but I would wait for one of the experienced fitters to weigh in.
Any fitters mind confirming the 7mm seat height difference?
Thanks in advance.
Does she have both sets of pedals?
Yes, she has both sets. Favero not installed yet.
She could measure them.
