First Tubeless Tire Setup
Going along with my previous first brake bleed post, I am adding a first tubeless tire setup post.
For background, I bought a new road bike last year with no research or prior experience with disc brakes and tubeless. I am an expert bike mechanic with most of the tools to do almost everything, but I added a few more for these projects.
My bike came fully set up, but I wanted to change the tires to 30mm Vittoria Corsa Pro based on a lot of feedback on this and other sites. So after a year of riding, I decided to pull the trigger during my pre-season maintenance.
Overall, it went a lot easier than I expected. I did screw a couple things up and wish I had a different sealant injector, but all was easily corrected. Here are a few of my thoughts and learnings…
  1. Getting the old tires off was a little challenging. If it matters, I have hookless ENVE 3.4 wheels, and one bead would not break free from its shelf into the center channel. I had to fight it. After that, it was a snap.
  2. Getting the new tires back on was also much easier than I expected. No different from tube tires.
  3. A compressor is a must-have for seating the tires. I tried a pump multiple times and was close, but they needed the blast. And, I did not want to waste a CO2. I used my compressor’s standard Schrader chuck on the stem with core removed. Pop-pop-pop, and it was seated.
  4. Accurately measure the sealant. My first screw-up was using Muck-off in a pouch. I could not tell how much I was putting front and back. In retrospect, I don’t think I squirted in near enough. My back tire was leaking, so I decided to re-do it.
  5. I picked injectable sealant for a several reasons…
    1. I rarely get flats, so I was not concerned about superior sealing abilities of non-injectable sealants like Silca
    2. It looked like I would make a colossal mess trying to mount a tire after pouring a 60ml in the bottom of a road tire
    3. I wanted to be able to top-off periodically without removing the tire
    4. Stan’s regular seemed highly regarded and also injectable
  6. For my re-do of the leaking tire, I bought a Park TSI-1 injector, which I do not recommend. You cannot clamp the hose which makes filling the injector difficult. I will probably replace it with something like a Stan’s or Silca injector with a hose clamp.
  7. I replaced my valve cores, thought I don’t think that was necessary.
  8. Don’t forget to clean the wheels during and after. It is still messy.
How is the ride with 60ml of sealant? I’ve been tubeless for a a while and have never gone over 30ml with my 28mm tires on my road bike. I ride on rough Texas chip seal. I go with 45ml in my 42mm tires on my gravel bike. Maybe I am putting too little sealant in? I do go with 60ml in my 2.4/2.35 MTB tires, though. Also, I went from using a compressor to the Airshot for seating tires and it works great.
Today was supposed to be my shakeout ride, but I got rained out. I followed the table for Stan’s, which calls for 50ml for 28mm tires and 55ml for 32mm tires. I rounded up to 60 since it was my first effort.
And I like the idea of that Airshot. I may get one for the next time I do a tire. Though, getting out my little pancake compressor is not too much a hassle.
The best tool for injecting sealant is a 2oz Stan’s bottle. Take your valve core out and squeeze it in the stem. One bottle full for road tires and two for MTB.
You don’t notice it at all. The sealant weight is negligible compared to the system weight. Biggest difference i guess is just that punctures will seal way better with more sealant
Just a thought. If you know anybody in medical, ask them to save a few saline flush syringes. The nozzles fit in a Presta valve stem with the core removed just right and they are graduated so it’s easy to measure out how much you’re injecting.
For a first time install I’ll add at least 30ml to for the initial coating/soaking of the casing, so 60ish total. Soap spray on the tire to ease the pop.
Minimum 30ml for top offs. I had to use 250ml of Vegetalex on my 76mm wide mini-fat bike. First 120ml soaked immediately into the casing :smiling_face_with_tear:
Any way, it’s worth rechecking after the first ride how much usable sealant is left until one becomes familiar with their brand (the pool that forms!).
In the future, Silca has fixed that issue. I’ve been a happy Orange Endurance user, but might make the switch when my giant bottle finally goes empty.
Dang, I missed that. Somehow I got caught up in all the prior noise and did not see the latest product is injectable. Now I want to replace all my stuff with Silca.
Brilliant! My daughter is a nurse, and I just told her about this idea. I shall have a few flush syringes to test with. She said the saline flush syringes are only 10ml, but they also have 60ml syringes for other uses.
I use the 10ml syringes myself. It’s what I have left over from when I worked in the hospital. Besides, I’m only running a 25c tire, so even for an initial mount, it’s only a couple syringes each.
The one thing I will say is the nozzle is a snug fit so there’s no room for air to escape as the sealant goes in. I just compress the tire before putting the nozzle in and release the tire as I’m injecting. Works well.
