… ____________________________________________ (aside from aerodynamics…)
Thinking some answers could be…
Better if you sit further… forward/back???
Have larger/smaller crank arm???
Like having total front end higher/lower
Wear X type of helmet…
However, interested in hearing Your Thoughts…
Essentially, what I am trying to gather (aside from being perhaps more aero) is why people prefer it…
Personally, just from looking at it, I always thought it would be more comfortable… But, when I’ve tried the position I’ve always shied away. Instead, I use parallels to ground s bars with hand position on up the angled part and in a more ‘choke up’ position with the pads a little closer to forearms than most. It takes some seasonal ‘adaptation’ and has never felt ‘optimal’. I am theorizing that why I use this position versus the higher position is…
- In the area I live there are not a lot of bike lanes, a lot of potholes and undulating roads, insane drivers, and I feel that slightly choked up S position gives me ‘better control’.
and
- (i’m not so sure of this one…) That from recent revelations it seems that I have a very large crank-arm length for my size and maybe this position helps me ‘scrape’ the bottom of the pedal stroke more…
This is kind of self reflective, but, the point to share my experience and learn how others feel…
Thanks for reading. Looking forward to understanding what your perspective is. Chris
Testing is the only way to know, but few people (very few in North America), have any understanding of this position or how to fit it. It’s far more than simply angling your forearms up from level or even raised. It’s a different position, and there are many adjustments that must be made to achieve a proper Mantis.
First, though, how do you define Mantis position? What angle are your forearms? At a certain angle, usually as you approach, or go over, 20 degrees, you’ll need support at the back of your elbows. This will not only give you proper support, but also better control over your bike. Mantis, in my mind, is any position that requires this type of support. Even with proper position adjustments and elbow support, not everyone can achieve Mantis comfortably. For those who can achieve it, it’s incredibly comfortable.
I was completely against Mantis, and tried to deny it for two years, but after testing hundreds of athletes in proper Mantis positions, I finally had to give in because there’s no doubt it’s the fastest position for the majority of people who can achieve it, and you’ll soon see products designed around this position to make it more comfortable and even faster. Still, I caution anyone to try this position unless they are already competent bike handlers, and there’s no doubt that, while it’s much easier to look forward with your head low in this position, your hands do compromise your field of view. Despite all the data, I still put very few people in this position. Arms angled up? Yes. Mantis, not so much.
