Now, I always have my road ID info on me too. I have a separate RoadID for time I don’t want to wear the tracker. It is not a perfect fit- tight squeeze- but it works WAY better than the fitbit clasp.
RoadID Elite. The clasp from the RoadID Elite will, if forced a little, fit the band of the fitbit Force. Same goes for the ID badge. You will have to cut the Force band… so be careful measuring, and if in doubt, cut too long.
Thanks for posting this amb - I’ve had the same roadid as you (the Elite I think?) for 3 years and received the fitbit force for Christmas. Loved the clasp of the roadid but did not like the fitibt at all. Found your post, did the same, and now it’s the perfect combination. Only issue I had was my id tag was just too tight, even in a vice with needlenose pliers. Ended up using a flat-head screwdriver to open it up just a little and it fits really snug now. Have been wearing the combo the last few days and its awesome! Thanks!
Glad you like! I had to open up my RoadID badge a little with a flathead screwdriver too. IMO, fitbit should ship with this clasp instead of the POS thing it comes with.
I fully recognize that this is a long dead thread, but I’m curious if anyone has had similar luck with some of the newer model activity trackers. I’m specifically looking at getting a Fitbit Charge or Charge HR and want to avoid having 2 bands on one arm.
I’ve been wearing the Garmin VivoActive, but started developing skin irritation (likely related to the charging port on the underside). I also like being able to wear a fashion watch occasionally, typically when I’m wearing work clothes. I tried a FitBit One, but found that I kept forgetting it on the previous day’s clothes.
TLDR; Need to ditch the smart-watch style tracker but want to keep one wrist-band on the other arm.
hacks are the best. Great job. just saw where you can get a id band that fits the flex and the charge /charge HR for good bit less than the road id tags. Check it out thefitid.com I ordered mine to fit the flex which I wear all the time.
