Felt Pulls Out the Stops on the Second-Generation Breed
This is Felt’s second major product release since November 2025, when Cesar Rojo and Florian Burguet completed a buyout to take 100% ownership of the company.
What Felt is Claiming with the New Breed
Comparing to the 2022 version of the bike, according to Felt’s internal comparisons:
  • 22.8% lower system weight (frame, fork, and cockpit combined). The frame is listed at 950g in size 54 in the FRD 12K layup. Complete bike weight on the FRD build with SRAM Red XPLR AXS is listed at 7.037 kg.
  • 10.5% lower aerodynamic drag, credited by Felt to new tube profiles, a redesigned fork, and the one-piece integrated cockpit.
Weight is an easy claim to verify; everyone has a scale at home and it becomes more of a power meter “+/-1%” argument.
But it’s pretty clear when you look at the provided overlay of the new Breed (blue) over the previous generation (gray) that they were able to remove a lot of material.
When it comes to the aerodynamic claims, it’s something that people are just going to have either see for what it is or not. In speaking with Felt, the claims come from CFD (Computational Fluid Dynamics), and that most of these savings come from the new head top and unified front bar.
What About the Fit?
Felt describes the geometry as derived from its Nexar aero road platform, with reach and stack values claimed to be consistent across the two bikes.
Size XS/49 S/52 M/54 L/56 XL/58 XXL/61
Rider height (cm) 155-163 163-170 170-175 175-180 180-188 188-196
Reach (mm) 365 370 380 390 395 405
Stack (mm) 522 537 558 576 600 631
Head tube angle 70.0° 70.0° 70.0° 70.5° 71.0° 71.5°
Seat tube angle 75.0° 75.0° 74.5° 74.5° 74.0° 74.0°
Fork rake (mm) 55 55 55 50 50 50
Trail @ 45C (mm) 71 71 71 73 69 66
Chainstay (mm) 430 430 430 430 430 430
BB drop (mm) 77.0 74.5 74.5 72.0 72.0 72.0
Wheelbase (mm) 1008 1018 1036 1044 1053 1067
Some observations from the published numbers: first, head tube angle in size 54 is 70.0°. Most current aero-focused gravel race bikes specify 71° to 72° in the equivalent size. The Breed’s figure is closer to endurance gravel geometry than to the steeper end of the race category.
Head tube angle and fork rake both vary across the size range — 70.0° to 71.5° on the head tube, 55mm to 50mm of rake. The result is trail held in a 66-73mm band across six sizes. The alternative approach, common at this price point, is one head tube angle and one rake across all sizes.
Chainstay length is 430mm on every size. Bottom bracket drop varies with size: 77mm on XS, 74.5mm on S and M, 72mm on L through XXL. The frame accepts tires up to 54mm front and 52mm rear.
And a surprising thing to see on an “aero gravel bike” is up to four bottle cages mount inside the frame. The frame is also marketed as compatible with suspension forks and dropper posts; Felt has not published which forks are validated, axle-to-crown range, or recommended dropper travel and insertion specifications. These are things that I don’t know why other bike brands don’t do in this category. It’s just odd to me when they don’t give someone the ability to add a fourth bottle on a bike or option for suspension to turn it into a quasi-mountain bike.
The biggest question I have about the new and bigger tire clearance is what will Dylan Johnston do with the extra tire clearance.
https://www.instagram.com/p/DXhR5-EADow/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
The Lineup
Unlike the Nexar that we covered last month, Felt is all-in with SRAM on this bike. At the same time, the company has continued to partner with Vision and FSA for wheels and some cockpit configurations.
  • FRD — SRAM Red XPLR AXS 1x, Vision SC 45 SL, 7.037 kg
  • Pro — SRAM Force XPLR shifters with GX Eagle transmission rear and 10-52T cassette (mullet*), Vision SC45 i23, 7.864 kg
  • Expert — SRAM Rival AXS XPLR 1x, Vision SC45 i23, 8.302 kg
  • Race — SRAM Apex AXS shifters with S1000 Eagle T-Type rear and 10-52T cassette (mullet*), Vision Team 30 i23, 9.284 kg
  • FRD Framekit — Frame and integrated cockpit, FRD 12K Matte, 1.92 kg framekit weight
The FRD and Pro use Felt’s FRD 12K carbon layup. The Expert and Race use a UD standard layup.
Two of the four complete bikes — Pro and Race — are mullet builds: road shifters paired with MTB rear derailleurs and 10-52T cassettes. And Tires across all four complete bikes are Continental Terra Competition 45-622, in Race Rapid casing on the FRD and Pro and Trail Grip on the Expert and Race.
The Cockpit
The integrated one-piece carbon cockpit is claimed at weighing under 300 grams, and it’s alsowhere Felt claims it gets a lot of this bike’s aero savings from. It is the same cockpit that is on the Nexar road platform. It’s an interesting choice considering the lack of flare that comes with it. So far, I have liked it this bar on the road. But now I need to image being on a really bumpy descent and pretending to need to brake.
The OE cockpit ships in three size groupings tied to frame size: 80mm, 90mm, and 100mm stems paired with 360-400mm bar widths at the levers. An aftermarket range adds a fourth size with a 120mm stem. Bar reach is 75mm and drop is 120mm across every size.
And all but one build of the bike includes the one-piece carbon cockpit; the Race build uses a conventional FSA NS SMR STEM and FSA A-WING AGX ALLOY HANDLEBAR
FSA A WING AGX AL HANDLEBAR:
49 / 52 / 54 / 56: 420mm
58 / 61: 440mm
FSA NS SMR IIAL6061
Size 49 / 52: 80mm
Size 54 / 56: 90mm
Size 58 / 61: 100mm
Thoughts
The updated Breed enters a category that has filled in significantly since the predecessor launched in 2022. Aero-focused gravel race bikes from Cervélo, Specialized, Trek, BMC, Pinarello, Factor, and others are now in market, all targeting the same race-format customer. I do think Felt is sticking to this theory on this bike they desiged. They aren’t trying to be the best at any one thing, they are trying to be great across the board. And they do hit a lot solid check marks on this bike. I like the lean into the 12k Carbon Weave on the frame. But I’m not a huge fan of only offering one component spec in given ranges. Especially if you’re going to share so many other features that might incentivize people to buy more than one bike from you.
In terms of what really has changed from the old Breed to the new one:
Head tube angle: Size 54 is 0.5° slacker than the old bike — One could say that the more aggressive feel comes from rider position, and not just front-end geometry.
Frame weight: 950g (FRD layup, size 54), down from an estimated 1,100g on the previous Carbon Advanced which in line with the new UD frame in M size is 1,140g.
Rider position: Stack drops 17mm in size 54, putting the rider lower over the front end.
Cockpit: Felt one-piece integrated carbon cockpit replaces the Devox alloy two-piece stem and bar
Carbon Weave: Felt went to a higher standard 12K weave that is found on the IA 2.0 and NEXAR | FRD
Drivetrain options: 1x and mullet builds only; the 2022 BREED was offered in 2x configurations, the new lineup is not.
Sizes: Six (49-61), down from seven (43-61); the smallest size has been discontinued.
Seatpost: Straight 27.2mm across all builds; the previous Taperlock dual-diameter sleeve system that allowed a 27.2mm damped post or a 30.9mm rigid/dropper post is now gone
Geometry (size 54 head-to-head)
Spec Previous BREED 54 New BREED 54 Change
Head tube angle 70.5° 70.0° 0.5° slacker
Seat tube angle 74.0° 74.5° 0.5° steeper
Reach 385mm 380mm -5mm
Stack 575mm 558mm -17mm lower
Head tube length 130mm 103mm -27mm shorter
Top tube (horizontal) 550mm 533mm -17mm
Seat tube length 500mm 482mm -18mm
BB drop 72mm 74.5mm -2.5mm (lower BB)
Fork rake 50mm 55mm +5mm
Chainstay 430mm 430mm unchanged
Wheelbase 1040mm 1036mm -4mm
Standover 770mm 784mm +14mm
Sizes offered 7 (43-61) 6 (49-61) smallest dropped
Pricing and Availability
Model EUR USD
Breed FRD €11,799 $12,399
Breed Pro €7,099 $7,099
Breed Expert €5,799 $5,999
Breed Race €4,599 $4,899
Breed FRD Framekit €4,499 $4,099
The bike reaches authorized Felt dealers globally in May 2026. You can find your local authorized dealer here.
