I know the Trinity has a longer reach than my current Felt. Honestly though I feel a touch squashed on the the bike. Current arm pad stack is 673mm and pad reach is 417mm.
Does the following seem right?
Frame stack is 551mm
Frame reach is 528mm
My guess is:
Frame: 551 / 417
Pad: 673 / 528
in point of fact, frame geometry in triathlon has converged. there is scant difference between the frames now in their stack/reach numbers, however, there is not conformity on what those frames are called. if you look at your 551mm/417mm, there’s a pretty typical geometry now that is about 540mm/425mm, and that’s the Felt IA in 56cm, the QR PR series in 54cm, the Dimond in size M, the Speed Concept in L, so, you just have to look at stack and reach. however…
that’s not the most important part of this. what is really divergent is in the range of available positions these bikes give you, by virtue of their integrated front ends.
me? i would not buy a felt today. why? the frame is great, the geometry is great, but the aerobars are felt-designed and they’re at least 8 years out of date and probably more. unless i’m mistaken, they use that old profile J2 bracket motif of armrests bolted to extensions which are bolted to armrest clamps. that’s a bad design in my opinion.
cervelo, QR, canyon, even orbea, and others, have kept up. trek, specialized, felt, in my opinion, haven’t.
That said, I believe on all the felts, including the upper end frd etc. you can throw a tririg alpha one on there, or a felt dagger stem and any base/aero bar you want onto that (like Josh A. does). At least one of your example mentioned above, the QR, the frameset itself doesn’t include a specific bar, so you are left buying aftermarket anyway.
i don’t agree what what you wrote here. yes, you can aftermarket-configure a Felt, but that doesn’t make the Felt and the QR equal. QR chooses to let someone else make its aerobar, and the aerobars that are on those bikes are quite fine. they don’t need to be changed. in my opinion, there are some bike makers who are spec’ing bikes in ways that pretty much require that you make 2 spends: 1 for the bike, and 1 for the retrofit. i think the cervelo P Series is a great, great bike, but i think you almost have to immediately sub out the Vision hydration system for the profile. Felt, you have to get a whole new front end. so, you take the price of the Felt, add $1000, and that’s your bike. before the hydration. that’s another spend.
