I have been looking for a road bike for a while. I am between Cervelo R3 and Felt F4,…still haven’t ruled out caad10 either. For some racing and long training group rides.
I know and like the R3, but have not had an opportunity to ride F4 or know much about it. I do know its geometry is better for me though.
Felt frame in F lineup is different depending on #. Where R3 frame is always the same, with different components.
How they compare I am unsure, any comparison or review of F series would be greatly appreciated.
edit:
I should say I am leaning towards the Felt, but I am very concerned.
Cervelo R3 with ultegra is 3900$, Felt F4 (ultegra) is 2700
I am concerned that Felt’s frame has cheap carbon, or perhaps these bikes are just not comparable.
Like I said R3 frame doesnt change, but even with 105 components, the R3 is 2600 and Felt F5 (105) is 2000$. Just caused some question in my mind.
Let me start by saying there are almost no “bad” bikes on the market today if you are spending $3000. The above poster that reported on his experience with a 2007/2008 Felt F2 won’t provide especially useful feedback as that frame, its construction method and engineering metrics have long since been retired. The new F-series molds fit 25mm tires, indeed both Garmin and Argos used Vittoria’s 25mm tubulars in their bikes.
The Felt F4 uses a blend of carbon fiber materials in the lay up. It uses the InsideOut molding process that our F1 and F2 use. The F3, F4, F5, and F6 use a mix of tough fibers to withstand the rigors of road use and provide compliance in the vertical plane. 5T, 24T, 30T, etc… are among the flavors. There is good information out there that can help you understand why and where these materials are used. Here’s one source: http://www.skchemicals.com/...ind/flex/sitemap.asp
It is important to understand why the properties favor a particular usage. Fiberglass is used on Felt frames. We use it only on bond areas that get machined before gluing such as the inside of the ends of the stays when they are bonded to aluminum dropouts. Some of our competitors use fiberglass in the lay-up itself using it as a strength additive and cost saving measure.
I would be shocked to learn that an R3 had some of the more exotic and costly materials like our UHC Ultimate’s nano-resin, 60T carbon fibers and Oxeon’s TeXtreme spread tow fabric with FAW as low as 76gsm.
What has you concerned that the Felt uses “cheap carbon” and what constitutes cheap carbon in your mind?
If the Felt were more expensive would it provide more credibility to our unrivaled investment in carbon technology and manufacturing?
The fit is going to be the biggest difference. The R3 is more similar to our Z series in terms of S/R. The CAAD10 and F are closer.
If you have any specific questions about the nitty gritty of the frame lay up, the materials source and usage in terms of why and where the different fiber properties are used, or the differences between the Felt construction methods let me know.
-SD
