Does anyone know if the baynet fork V4, now available only on the 2014 DA2 will be available as spare and will fit older version of the DA/B2 series frames? (superdave?)
BTW…the fact that nobody is talking anymore about the flat fixed stem for the bayonet 3 is because they are now easy to find or simply because we gave up?
Cheers
I was lucky enough to come across a pro take off, which according to SuperDave will spontaneous combust.
I took some time off complaining about it, but I’m still waiting (4 years and counting from '10).
Cheers
The Bayonet4 will not be offered as an aftermarket upgrade for older DA models. It wouldn’t fit the older B2 frames at all as the shape is totally different.
The flat fixed stems have not been released for aftermarket sale.
Cheers
I don’t recall saying it would combust. The stem you have does not fit our latest Bayonet carbon handlebars. The stem you are riding on fails fatigue testing so we decided against bringing that design to market.
Thanks Dave as always for the support, i was just curious since apparently there is no picture around the internet of a DA2 with a flat (90mmL x 0mmY) stem!!!
Are there other stem sizes now available for the bayonet 4?
the bike comes with both the 30mm rise and 0mm rise stems in 70 and 90mm length. what size did you need?
-Dave
Not sure, but I can envision the possibility of wanting to change the rise without changing the length.
We cannot make a 70mm x 0mm because the clamping mechanism of the fork would interfere/overlap with the clamping mechanism of the handlebar.
Of course you can just move the arm rests and extensions back 2cm and cut the ends of the base bar 2cm at the brake levers to “create” the same position a 7cm would give you. The Bayonet3 bars are designed with huge “X” fit range in mind.
-Dave
-SD
I was actually thinking more of a 90x30. I just got a 2014 DA2 and it currently has the 90x0, and I’m playing with the fit myself before I consider a fit session. So far, I think the stem length is good, but I may want to raise it some. I currently have 20mm spacers for the aero bars and I guess I can go to 30 or 40 to raise those, but that creates a larger drop to the base bar…which may be fine…not sure. I know you can flip the whole base bar over to create more rise at the ends/brakes, but not sure I’d want to go through that trouble and I doubt I’d like the look. The aero bars also seem to be a little short with the DI2 setup. I’m not sure if they were cut before being sold to me or what, but I don’t think my arm length is particularly long (about 18" from fingertips to elbow). I’m very new to tri bikes and terminology, so I’m not sure how clear my comments are. I do love the massive adjustability of the Bayonet 3/ Devox setup.
-Dave
-SD
Flip the base bar over so you get the rise from the bar without adding any additional frontal area. The bar is 100% symmetric as is the case with all our Bayonet handlebars.
-Dave
-SD
-SD
2015 DA with Textreme carbon fiber improves the 2014 DA in what ways (grams, stiffness) and same question for the AR FRD versus AR 2???
Seriously looking at purchasing 2 Felts but weighing the relative merits of 2014 DA vs 2015 and the 2015s AR FRD vs 2.
Thanks.
The TeXtreme on the DA1 in 2015 improves impact damage resistance and shaves ~75g from the 54cm frame weight. You also get the new VR module in the seatpost for a more comfortable ride. Stiffness and aerodynamics are kept the same as the 2014 DA2.
The AR FRD is both stiffer and lighter than the AR2. This is the only example where the premium frame is made to be stiffer than our other lower grade lay ups. The AR FRD was made to the same stiffness requirements as our F FRD. The AR2 is no slouch though as it’s been proven with 20+ professional wins this year most of them coming in criteriums where stiffness is crucial for all the 25-35 mph accelerations repeated over and over lap after lap. The VR module is included in the AR2 as well and while it adds a few grams, it does improve the seated ride compliance.
If I were honest, the DA1 and AR2 would be the way to go for most consumers. If you’re the kind of guy that has to have the best of everything, the DA1 frameset with some Di2 shifting components and the AR FRD bike are for you.
The wind doesn’t know how much money you spent but it does know if you settled on a slower frame from another manufacturer.
Thanks.
-SD
Thanks so much for the response SD.
Much appreciated. One last request and I have searched… is there tunnel data on the DA with the bayonet fork compared to other super bikes (other than the IA)??? Just not finding it.
Thanks.
-SD
Thanks again for the help on this. Went in to look at ordering and came away scratching my head… the AR FRD is electronic only? No conversion kit if you do want to run mechanical or am I mistaken? Regarding the tt bike, the DA is listed as mechanical compatible but I don’t see the same for the AR FRD?? The AR2 is mechanical compatible so if I went with that are we talking about 100 grams difference compared to the AR FRD? Finally, any data on the DA with the bayonet integrated front brake?
SuperDave, has Felt published assembly instructions for the Bayonet 4? Don’t see any on the website, like there are for the 1, 2 and 3 versions. Headset is loosened slightly, and the assembly order / torque values aren’t evident.
