Felt B16 vs B12 frame
Are the B16 and B12 frames identical aside from color scheme? I couldn’t identify any differences from the website and technical specs. Also, since the B12 frame is available as a frameset alone what are the odds I could convince a LBS to sell me the B16 with the B12 color scheme if in fact they are same?
B-12
Frame:
Felt TT/Tri UHC Performance MMC carbon fiber w/ 3KP weave, mechanical internal cable routing, aluminum dropout & derailleur hanger
B16
Frame:
It would appear you found all that is needed. Looks pretty identical to me. Doubtful on the LBS.
Not exactly the same. There is a slightly different layup with the B12 that uses 100% 3k cosmetic weave on the outside of the frame before paint. This yeilds a slightly lighter frame and the reduced paint also allows a slightly lower weight.
It is largely insignificant in terms of performance, but if you had a gram scale and time you could discover the difference between a B12 and B16 frame. You can’t tell from the saddle.
-SD
What are the odds?
Depends on several things.
How busy are they?
How many do they have in stock?
What are the chances they can sell the other frame?
How much are you going to incentivize them?
-SD
Does that type of “insignificant” difference occur in the DA series frames for 2012?
-SD
No, there are material, lay up, internal bladder, and larger weight differences between the DA1 and DA2/3/4.
-SD
-SD
is this also true of the 2011 models?
-SD
No.
