Looking to make some custom wedges and need the dimensions of the Enve aerobar spacers.
Length, width at widest, and width at the “nose” and “tail” of the spacer. Also need bolt spacing.
thanks in advance.
thanks in advance.
bump. Is there nobody???
I have some spacers at home and can check if you need me to…
yes please… they’re boat shaped right?
Yes, they are. I’ll get that to you later today…
Let me know if this is helpful. I can do any more you might need, or even send you one to look at if you’d like. I want to keep them but am not using all right now…
http://i63.tinypic.com/k6x54.jpg
I also found this in case you need any of that info…
thank you
Anytime!
thank you
Gary can you have a look at this? Maybe print it out and lay a spacer on it?
https://enve.app.box.com/s/163qrljl6a4kxu18qto2
Hi Eric,
Not sure what you want…another photo with the spacer on top of a print? I added the scale for “calibration” so if you got that to the actual size, the spacers shown would be actual size. Guess I’m not following what you need…
Does this help?
Shape not very good as I drew around a pic.
wow that’s awesome too. thanks to you both!
