Endura QDC D2Z trisuit sizing
Guys looking at getting endura D2Z trisuit - and wonderign about sizing - from the matrix chest/waist on their site it seems i should be small. However never worn anything from them
In castelli cycling I am L
In most i am M
in LG M2 trisuit I am S
anyone tried it on. Appreciate. I am 5’10’’ and 31 waist Swimmers build not cyclist
Should hopefully be able to help in a few days.
I’m waiting on a sample size to come out to double check sizing.
Similar build to you I’m 174cm, 31"waist, 65-68kg and generally a medium in clothes but small in fusion speed suit.
Should be a small in qdc and will know in few days. Will post then.
would be great esp that my fusion is M
I’m also interested in your thoughts. I am 173 and 71kg. According to their size chart, I should be XS! I wear seize M in Zerod osuits.
any update on your endura?
Yep I got the small and medium sample to try.
I could fit into both, but granted the small was a bit restrictive.
Now on both, there was a gathering of material around the front of the shoulder area.
Strange and despite the tightness just didn’t seem to suit my body shape.
The main issue however was in the neck line.
On both sizes, the neck line cut into my skin and was uncomfortably tight.
I was surprised at this as Joe Skipper’s suit is a low neck line and same for Nils Frommhold.
On querying this they have the older models and the new model for some reason is a much tighter cut around the neck.
I couldn’t get it to work, and they do not offer an alternative or other fit so unfortunately for me it was a no go in both sizes.
I’m 174cm, 66.5kg and a medium build - would have broad shoulders for my size but nothing major.
Didn’t realise my neck was broad but for the purpose of this fit it appears so.
Pro’s:
  • I feel it’s likely one of the most aero
Con’s:
  • Restrictive neck line on current new fit/model
  • rear pockets actually seemed a bit awkward
All about fit, good luck in your hunting.
I’m now in search of a bioracer or stick to my fusion at the mo.
Not many in size small about it appears, so next few races likely with the fusion.
No complaints as fits well and no bunching around shoulders.
Ps on sizing I’d say anything above 67-68kh would be a size medium.
Possibly a large if above 71kg or so at a guess.
Worth asking for the medium and large sample suits if an option to see how fit is for you.
If you’ve a swimmers build then neckline may be an issue for you also so defo worth checking first.
thanks that helps a lot … i think its pass for me - i am acutely aware of the neckline issue
Thanks a lot for your review. I’m the same weight and height as you but may smaller build. I’m still debating on whether getting the two piece (convenience of bathroom breaks) or one piece (for it’s “aeroness”). I’ll order both s and m and see how either one fits.
Sorry to bring up an old thread but has anyone actually tested one of the endura suits?
There are a fair few pros in them now, Tim Don to name one, but not many people seem to be using them?
