Just recently i saw a video where elastic laces were metioned as bad for your feet. They reccomended to use them during racing only and not during training. The reason they explained for this is that with elastic laces, the laces flex slightly during running alowing your feet to move around more in your shoes causing friction (blistering) and your feet are not supported as well as they would be with rigid laces, putting more strain on them. The latter was claimed to possibly cause feet injuries.
This made me wonder. Is training with elastic laces indeed increasing the risk of foot injury? What do you think?
Sounds like BS to me. I’ve been using elastic laces in all my shoes for 10 plus years with no issues. Many in the running club use them I haven’t heard a thing from them.
I saw that video and you made me watch it. It’s just as possible to pull your elastic laces tight over your foot as it is to pull a regular lace. I really can’t see the argument here. It’s a matter of comfort and if you are comfortable in your shoes with elastic laces then you are comfortable.
On the flip side my wife puts her running shoes on does not pull on the laces to tighten the shoe around and simply ties a bow knot. I can stick my finger between the knot and her shoe no problem. She runs just fine like that.
i swapped to elastic laces a while back and will never go back to classic laces. i dont have to spend time trying to get my laces properly adjusted anymore, worry that the knot may come undone while running, or taking the time to fiddle with them in transition. i just slip my shoes on and run.
I love the Xtenex brand!
Thekey is to find the right tension, if too loose your feet with move, if too tight will have pain afterward.
It usually take me two runs to find the right pressure
Never got an issue with them.
Count me in the camp who hates them. I’ve tried to like them, but because they’re always putting a bit of tension on my foot they wind up hurting my feet. Regular laces I can tie so there’s no pressure on the foot, unless the shoe moves on your foot for some reason.
For me, it depends on the shoes and the event. I use elastic laces in my racing shoes for all multisport races up to a half ironman, but don’t generally use them for training at all. I use regular laces for Ironman distance events. I never use them for pure running events…one year I left my elastic laces in my racers at Boston…ouch…had blood blisters under toenails of all 10 toes due to all of the downhill. Lesson learned! So, I don’t think I’ve helped you, but I don’t think it needs to be all or nothing:) Good luck!
Some shoes fit so well, it doesn’t matter how I tie the laces. These are fine with elastic laces.
However most of my shoes need some level of lock down through the mid foot to achieve a good fit.
When I set up a pair of runners with elastic laces, I take several runs to get the tension the way I want it and then I never touch the laces again. For them to be loose enough for me to get them on very quickly, usually means a slight compromise over normal laces. Once I have elastic laces in a shoe, I will typically only use this shoe for races and brick sessions.
Worth noting that of the 15 pairs I own, there would only be about 5 pairs that I would consider using elastic laces with.
And if I was generalising, I would definitely recommend doing the majority of your running with normal laces.
Good to read you guys’ opinions. I use several types of elastic laces for both racing and training and never thought twice about it. My preference are the bamboo laces with the ‘knots’ that allow you to ajust lace tension seperately for the different regions of your feet. Haven’t had any problems yet that i can link to the laces. That video made me wonder though, however the claims they make don’t seem to be supported by any scientific research or data from the medical field. Perhaps it’s just one of those things that’s differeny for every single person.
I tried this brand - the one with the knots - and I never got it fit right. What other brands are available?
Thanks, John
Thanks, John
Among others, there’s Tieloxx, Ulaces, locklaces, flat or round elastic laces and bamboo style laces. I order them from a local shop. https://veters.nl/Elastische-Veters?Lng=en
I also tried silicone laces i got from Decathlon, but i didn’t like those because they are more difficult to install and they are more likely to break.
I’m a big fan of the flat, ribbon-style elastic laces. However, whenever I’ve tried elastic laces with a round cross-section, I’ve usually ended up with hot-spots on the upper side of my feet.
I don’t feel any difference performance wise. In fact, I think I did my marathon PB with elastic laces, just because I couldn’t be bothered to relace my race shoes after a triathlon!
