Durability of swim jammers on the bike?
Now that I’ve finally replaced my bike, I’m wondering: will wearing swim jammers while cycling(3.5mi) to the pool and back wear out the swimsuits super fast? If so, will just putting some running shorts on over the swimsuit help?
I have yet to buy any tri shorts, and it hasn’t been a priority because I’d heard that I shouldn’t wear them in the pool anyway.
Or should I actually bother to pack a change of shorts, etc?
I’ve been running to the pool, but I’m blown on the run home. I also need to work harder on the swim than I do running, so I’m looking to do a lazy cycle commute so I can work on my swimming more-instead of having to save energy for the run.
Thanks for your wisdom, y’all.
Many low-end tri shorts are just jammers with a fleece pad. It’s the chlorine that will kill them well before any biking.
Many high-end tri shorts and biking shorts use very thin fabric that is great for riding, but would die quickly in the pool.
If durability is a concern, try PBT jammers (Speedo Endurance, TYR DuraFast, etc.) since they are basically chlorine-proof.
I’m in TYR DuraFast right now, actually. So they’re probably okay on the bike? Probably only about 20 miles on the week on the bike.
They should be pretty bombproof. For me the comfort issue with jammers is the seams when biking.
Just a thought here. “basically chlorine proof” doesn’t equal friction proof.
I’m not suggesting that you can’t do it, but the jammers will wear out in a particular area much faster. A 100% poly suit offers a high chlorine resistance, yes, but is not the same as a good bike/ tri short. I’m fairly certain (but could be wrong) that most cycling/ tri apparel has some type of Nylon, Spandex, Lycra, stretchy fabric in it. Those materials are generally absent from fabric composition in suits with high chlorine resistance, as those are the ones that break down faster in chlorine.
A poly suit is likely going to chafe a little also when wet (I think) Will it ruin the suit? Not quickly, but I think it might a little bit faster than normal.
Additionally, your higher end poly suits shouldn’t spend much time in the washing machine if any.
Just my thoughts…
jake
If you’re not riding far just stay out of the saddle.
I’d wear some cheap shorts to protect the jammers.
Yes. Beach swim trunks and fancy bike. Set a new trend.
Just my thoughts…
jake
I’ve done some medium length rides and one 70.3 in a poly/PBT suit. The durability seemed fine; this biggest drawback seemed to be comfort: seams, and the lack of stretch compared to a Lycra blend.
Assuming the OP is comfortable enough during the rides, durability should be OK. Plus, poly jammers are cheap (you can get them for $30, and they last a couple years…IME the stitching is what finally goes).
I’ve done loads of training at home in speedos, and used them under knicks because it saved having to wash the knicks too often but still allowed for a clean layer each ride. While they are briefs, not jammers, I can’t see them being any better, possibly even worse than jammers due to the rolled edge around the leg. One thing that might be a problem is them wearing out on the inside of the thigh.
Thanks y’all. I won’t worry then. I just didn’t want to be buying new shorts every couple weeks.
A trendsetter; that’s me.
Does a sub $1k bike with sora count as fancy?
Speedo bro.
